How should I setup my home network?
Please help me set up my home network.
I have a:
  • Fiber optic modem router (from ISP)(wifi disabled)
  • Mikrotik hex S (rb760iGS)
  • 2 x 5-port switch (to wired devices)
  • 3 x Tenda nova mesh wifi nodes (each one wired to the switch ports)
My IP setup so far:
  • Fiber optic modem router 192.168.1.1 - DHCP server 192.168.1.3 - 192.168.1.63
  • Mikrotik hex S (rb760iGS) 192.168.1.2 - mode ROUTER - DHCP server OFF - NAT OFF
  • 3 x Tenda nova mesh wifi nodes (each one wired to the switch ports) - set as BRIDGE
My goal is:
I want to make a hotspot system at my home, so that users who wishes to connect to the wifi would need to login through mikrotik.
How do I do this?
Is my initial setup correct?
I seems to have some trouble connecting the mesh wifi nodes to each other, this does not happen before when I just use the switches in my system. It seems like their access is being blocked by mikrotik somehow.
# apr/26/2020 15:54:05 by RouterOS 6.46.5
# software id = E0QH-G6RQ
# model = RB760iGS
# serial number = A36A0BFEA28A
add admin-mac=C4:AD:34:4E:4B:C1 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add address-pool=default-dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge disabled=yes interface=ether1
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=sfp1 list=LAN
add interface=bridge list=LAN
add address=192.168.1.2/24 comment=defconf interface=ether2 network=\
    192.168.1.0
add address=192.168.1.2/24 interface=ether1 network=192.168.1.0
/ip dhcp-client
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.62 netmask=24
set allow-remote-requests=yes servers=45.126.80.8,45.126.80.88
/ip dns static
add address=192.168.1.2 comment=defconf name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
add distance=1 gateway=192.168.1.1
/system clock
set time-zone-name=Asia/Jakarta
/tool mac-server
/tool mac-server mac-winbox
I’ve finally managed to setup a hotspot network at my home, with my tenda nova mesh wifi.
However a new problem emerged now, which I will ask in another thread so as not to blur the topic.
Wifi signal dropping every few minutes (and then got back up). I don’t know what could have caused this.
When I set my mesh access point as ‘bridge’, interface always link down link up.
What could have caused this?
