Running version 6.49.18
I have an issue where SNMP probing goes out from the wrong interface : the probing comes from the main VRF instead of the VRF where the IP address exists.
The target have a dynamic route (it won’t appear in config file/export) and the src pref ip from the dynamic route is the correct one, within the correct VRF.
I tried to create a mangle prerouting rule for the target to set the correct routing table, without success, but maybe I need a return rule somewhere?
I wasn’t able to find threads of The Dude users where VRF are active.
(And sorry, no, I won’t put a full router config here as I won’t be able to censor it correctly, if there is documentation to make it work with VRF, or a generic example, that will probably do. I can share specific config parts if needed : i’m pretty sure you don’t need the VPN and PPP settings or the user list
