How To 802.1X EAP-TLS?? HELP pls
Hi Guys.
Im looking for some manual or documentation about how to configure Mikrotik for use it with EAP-TLS and Active Directory.
· I have installed the Radius server and the Certification Authority in the Active Directory.
· I have created the certificate and the security policy.
· I have created the NPS network policy.
I have managed to run the Mikrotik as an access point by logging in using Username / Password like a simple 802.1X Eap.
I can do it configuring Mikrotik like this:
But I need that demand me the certificate from the client side (802.1x EAP-TLS).
If I’m try to change EAP method from passthrough to EAP-TLS, I can’t establish a connection.
When I try to connect, it ask me for credentials of user/passw and When I enter it, then ask me again for a password..
On the Mikrotik logs I can see it:
What I should do for make it work??
If need some documentation more about it (Active Directory, Cert. Authority, NPS..) just tell me.
Thanks guys.
I’m try some changes without succesfull result..
I add the “Suplicant Identity” with the same name of the CN. But did not work.
I also tried to upload the certificate in extension .CER and .KEY, but it didn’t work either..
I don’t know what else to try, since without a certificate I connect well with credentials. That means that it connects the network policy and the active directory well
No one knows anything?
There is no documentation about it?
Was there ever a resolution on this? I’m having the same issue
