How to access another LAN network in same MikroTik router
Hey Folks,
I am working in an ISP and I am running two networks on a single MikroTik RouterBOARD 962UiGS-5HacT2HnT, port 1 & port 2 act as WAN for both seperate connections and port 3 & port 4 act as LAN for both the connections (LAN 1 is 10.50.50.0/24 & LAN 2 is 192.168.50.0/24)
I am running an EMS server v2.3.7 (for GPON OLTs) on a PC in LAN 1 having IP 10.50.50.201 running on port 8888 and I want to be able to access the same on all the systems in LAN 2. I am not sure on how to achieve the same, and I had tried simple port forwarding using NAT rules for dst-nat but It did not work.
Please advise as to how I can get it to work.
Thank you
