I have a server on my LAN that I have exposed in DMZ with a couple of src-nat/dst-nat.
Its public IP address is different from the mikrotik WAN IP.
I added a NAT rule like this (sorry, I use winbox):
Chain: dst-nat
Dst-address: DMZ public IP
In.Interface: LAN
Action: dst-nat
to address: LAN private IP for the server
What happens is that I get to the mikrotik instead of being redirected to the server.
The logs have been useless, to me at least.
Any hint?
Thanks.
That works.
But it’s interfering with the filtering dst-nat rule that comes before.
I have a first dst-nat rule to allow the access from internet to the DMZ server only with a few protocols.
While the second one that you suggested (and works) allows all protocols, as it should be.
What happens is that the second rule “overrules” the first one, allowing all protocols to the DMZ server…
I actually need a “limited” dst-nat when coming from the Internet and an “unlimited” dst-nat from LAN.
Where 10.74.1.222 is my DMZ server.
Now, if I point my browser to the second WAN IP address I get to the LAN server 10.74.1.222.
But two main problems remain:
I don’t fully understand why and how it works (my bad!)
It works for all WAN IPs.
I was expecting a simple dst-nat rule to dst-NAT all traffic from LAN to the chosen public IP addresses on WAN to the LAN server itself.
