how to access NanoBeam M5 16 configuration from BusyBox
Hi - I have a new “NanoBeam M5 16”
I dont want to use browser not GUI, I want to use PUTTY and Busybox.
What is the command to display antena configuration, as SSID, wireless IP, etc
Thanks - any pointer to any URL is welcome.
https://community.ubnt.com/
Would be better asked in the UBNT forums but in the spirit of trying to help.
SSH in and use;
vi /tmp/system.cfg
When finished, save, write, exit and then use
save
To save the config.
Thanks, coleagues - shall I (1) repeat the question or (2)you can “move” it ?
I will try (1st)
You can do (2nd) if neccessary
Thanks.
Your topic couldn’t be moved, the Ubiquiti forum is a completely different manufacturers community website. The response was both tongue in cheek and actually exactly what the answer should have been, it was only luck I had just done similar then checked forums.
I am on both forums and for a moment I thought that I was on the wrong forum…
