How to access the configuration of my router, MikroTik?
The ISP told me that only they can be accessed. But I wonder if there is any way I can get into my router settings?
I put in the url of a web address window and also 192.168.0.1 192.168.1.1 192.168.2.1 and me and also redirects RouterOS RouterOS v6.10 and v6.12 You have connected to a router. Administrative access only. If This device is not in your possession, please contact your Local network administrator.
192.168.1.1 and 192.168.2.1 and put I put in WebFig Login Login and Password “admin” “admin” and “1234” and I can not access …
I have wifi ASPWIFI contracted with the company and an antenna on the roof.
The router that is on the table of the house, a router (wired router feeder POE) and a feeder poe (POE feeder cable to the antenna above) and up on the roof antenna
How to access settings in my router, MikroTik RouterBOARD 951-2n model?
If the Mikrotik is given to you by your ISP, a so called WISP, it would be better that only they are
able to have access, preventing you from turning on things that could be harming the entire network of them!
