hi every one …suppose you have any mikrotik device such as sextant 5hnd .you use this unit as internet connection .
the question is / can we access this device from any where in the world ( by using the internet )
what i have to do to access this device / i mean what are the settings in this device we have to do to make this option
please need your help
you are supposed to put static ip on the router
give karma if i helped you
thank you very much for your replay
let’s say that the ip of the device = 10.10.10.1/24
you say that i need a static ip = puplic ip …how can i know that puplic ip
please give more information about the settings
You need to setup a VPN connection from that device to another device (such as your core router) that has a static public IP. Then you can remotely VPN to your core router and access the device from anywhere. This is the basic idea of a management network.
thank you very very much for your replay…
so i need the following things to perfom the idea/
1- router or core router as you say
2- vpn between my device and the router
3- static ip for the router
4- no more?
can we say the issue is simillar to set surveilance camera ?
Yep, technically you could have DHCP instead of static but you will need a ddns service and some scripting. It is just easier with static.
What do you mean about the cameras?
surveillance camera = ip camera.we need it for home,office,..etc
to set ip cemera we need somthigs/
1- static ip
2- ddns
3- internet connection like router
you need just a public ip on your router THAT’S ONLY IS REQUIRED TO HAVE ACCESS ON THE ROUTER FROM ANYwhere .
