How to achieve my Setup?
Hei there,
i am a sound engineer, new to RouterOS and i have a hAP ac lite. I want to have the following setup:
Ethernet Ports:
1- WAN, to plug internet on it
2-5 - LAN on autoip range (i need the plugged in devices to be on auto ip, because i will need to unplug the switch after being finished working on them. These are Dante-enabled wireless microphone devices, which cause a audiodropout when being unplugged from a dhcp server and reconfiguring themselves with autoip config)
WIFI - 192.168.1.x range with dhcp server to have the connected devices receive an ip from the hap ac lite.
LAN and WIFI should be able to interconnect. Also it should be possible to have internet via the WAN port on all connections if needed.
Is this possible to achieve?
Sorry for my bad english. :slight_smile:
I really hope to get some hints here from you guys.
Thank you in advance,
Raimund
Dont be afraid to use google translate to provide your ideas.
Very confusing about the mikes, and a diagram might help.
I still have no clue what role the switches have with the mikes and why you install the switches and take them away.
There is no such thing as autoIP. The router will assigne DHCP leases to devices that connect to it.
The one option you have is to set the lease as static/fixed so it never changes which sounds close to what you want???
