Hi all,
How can I add my AccessPoint with port address? Because my devices behide the Router. I can access with port but can’t add this to dude server.
Thanks.
Hi all,
Thanks.
jamecollins,
If I understand correctly, port you are trying to specify is used only for SNMP.
Any another device probes are added inside a “Services” tab.
Dude support this in the way described in the next post.
Thank you!
jamecollins,
Feature request - Specify custom SNMP port for the device [SOLVED]
Thank you!
Thanks for your reply but I think you don’t get my idea.
Because my AP behinde the NAT, that why I’m using 50000 port to connect to my device. Port 5000 will be NAT to my accesspoint on port 8291.
Now I want using the dude to management this device. How can I do that? I have tried follow your post but this not work.
jamecollins,
In your case you want that Dude access your ROS with non default port. You may try to follow guide in the following forum topic: Adding RouterOS device with no default port , adding images problem
Thank you!
