Good day every one.
Please I need urgent assistance with adding Grandstream IP Phones to my network.
Task: I want to use Mikrotik to manage bandwidth in an existing network.
Problem: The IP Phones stop working after the introduction of mikrotik routeros.
Can some one help with the configuration on how to make the ip phones work with mikrotik?
IP Phones have server ip of 10.1.1.18
Thanks.
Hi
Did you make sure required services ports under /ip firewall service are enabled !?
Sent from my TECNO Camon CX using Tapatalk
87.4 is the answer…Well, that’s the answer I’ve come to taking all of the specifics you’ve mentioned so far.
You are going to need to give a lot more information if you want help though. Maybe a diagram showing network layout, where the MikroTik is in relation to your phones and server?
hi,
any ideas on this thread? I’m currently having the same issue
regards,
You should start a new thread. This one is old and the OP posted no useful information.
Explain in detail what issue you’re having, and for the fastest response, post the output of
export hide-sensitive
