How to add hotspotuser to Active by script
Hi!!!
My situation:
I use hotspot with radius authentication? and dont want that users often goes to login page. one time in week to be good. So i use Hotspot Cookie. But this solution have one problem. after reconnect when user goes to any url(except https. https links before authentication not work) hу redirect to :
http://172.16.3.1/login?dst=http%3A%2F%2Fwww.gmail.com%2F
with this content:
({ ‘logged_in’ : ‘yes’, ‘link_login_only’ : ‘http://172.16.3.1/login’ })
and only after this can go to internet, and onle after this his profile adds to hotspot active tab.
Now question:
is it abble using script or by another way(firewall rule) to add user(if he was on cookie) to active after his just connected to WiFi??
