hi all,
i play around with capsman for whole day today and i can not find how to adjust the tx power for caps.
does anyone find what am i looking for ?
or the menu is not available ?
thank you
Paul
hi all,
thank you
Paul
/caps-man interface channel tx-power
ok thank you…
i find it out a week ago.
Paul
I mean… I did answer 2 hours and 36 minutes after you posted…
However according to Mikrotik you are not supposed to adjust tx power, only antenna gain.
http://forum.mikrotik.com/t/simple-wireless-tx-power-and-antenna-gain/108856/1
http://forum.mikrotik.com/t/decrease-tx-power/115785/1
Is that the same for caps-man?
So in caps-man we are supposed to lower transmit power.
I am (and it is working perfectly)
Aside from all the mikrotik WiFi glitches... lowering power level like this has worked for me too.
