we want send default route to a particular peer.
In BGP peer, we have tried to set
default-originate=always
or
default-originate=if-installed
without success.
The only workaround that we have found is to create a out filter with discard action
/routing filter add action=discard chain=peer-out
But with this rule, the peer dont receive any rute.
What is the correct way to send refault route?
Thanks!
