How to allow LAN - LAN connection
Hi all,
This is newbie questions, I have RB951G and try to setup 2 private LANs
  1. LAN1 192.168.2.0/24 (WLAN + Port 2, bridge),
  2. LAN2 192.168.3.0//24 (Port 3)
WAN is on port 1.
Problem:
  1. I can not ping/traceroute access services from LAN1 => LAN2, or LAN2 => LAN1
What I want to achieve:
  1. Allow LAN1 => LAN2, or LAN2 => LAN1 accessing each other services
  2. Allow port forward from WAN to service in LAN2 (for example http/80)
    I hope someone can enlighten me. Thanks
Best regards,
Riwut L
This is my settings
[admin@redmond] > /ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   ;;; default configuration
     192.168.2.1/24     192.168.2.0     ether2-LAN
 1   192.168.3.1/24     192.168.3.0     ether5-TO-DLINK-Bridge
 2   192.168.2.254/24   192.168.2.0     bridge-local
 3 XI 192.168.0.2/24     192.168.0.0     bridge-segment-3
 4 D 116.88.61.222/24   116.88.61.0     ether1-Public-1
[admin@redmond] >
Firewall
[admin@redmond] /ip firewall> filter print
 0  D ;;; special dummy rule to show fasttrack counters
      chain=forward
 1    ;;; default configuration - Accepts ICMP
      chain=input action=accept protocol=icmp in-interface=bridge-local log=no log-prefix=""
 2    ;;; default configuration - Accepts Established / Related Input
      chain=input action=accept connection-state=established,related log=no log-prefix=""
 3    chain=input action=accept in-interface=ether5-TO-DLINK-Bridge log=no log-prefix=""
 4    chain=input action=accept in-interface=bridge-local log=no log-prefix=""
 5    ;;; default - DROP input
      chain=input action=drop log=yes log-prefix="Input Drop"
 6    ;;; FastTrack Established/Related Forward
      chain=forward action=fasttrack-connection connection-state=established,related log=no log-prefix=""
 7    ;;; default configuration - Foward Related/Established
      chain=forward action=accept connection-state=established,related log=no log-prefix=""
 8    ;;; Forward LAN >> WAN
      chain=forward action=accept out-interface=ether1-Public-1 log=no log-prefix=""
 9    ;;; default - DROP Forward Invalid
      chain=forward action=drop connection-state=invalid log=no log-prefix=""
10    ;;; default configuration - Drop Any Into GW
      chain=input action=drop in-interface=ether1-Public-1 log=no log-prefix=""
11    ;;; DROP BOGON
      chain=forward action=drop src-address-list=Bogon log=no log-prefix=""
12    ;;; DROP FORWARD
      chain=forward action=drop log=no log-prefix=""
Nat
[admin@redmond] /ip firewall> nat print
 0 XI  chain=srcnat action=masquerade protocol=tcp out-interface=ether1-Public-1 dst-port=53 connection-mark=USA-Limite>
 1 XI  chain=srcnat action=masquerade protocol=udp out-interface=ether1-Public-1 dst-port=53 connection-mark=USA-Limite>
 2    ;;; UnLocator DNS for HULU, NetFlix
      chain=dstnat action=dst-nat to-addresses=54.251.190.247 to-ports=53 protocol=tcp dst-port=53
      connection-mark=USA-Limited log=no log-prefix=""
 3    chain=dstnat action=dst-nat to-addresses=54.251.190.247 to-ports=53 protocol=udp dst-port=53
 4 XI  chain=dstnat action=accept protocol=tcp src-address=192.168.3.10 dst-port=80 log=no log-prefix="loh"
 5 XI  chain=srcnat action=masquerade protocol=tcp out-interface=ether1-Public-1 dst-port=53 connection-mark=USA-Limite>
 6 XI  chain=srcnat action=masquerade protocol=udp out-interface=ether1-Public-1 dst-port=53 connection-mark=USA-Limite>
 7 XI  ;;; UnLocator DNS for HULU, NetFlix - bypass Web Proxy
      chain=srcnat action=masquerade connection-mark=via_unlocator_conn log=no log-prefix=""
 8    ;;; Transparent proxy DNS
      chain=dstnat action=dst-nat to-addresses=192.168.2.1 to-ports=53 protocol=tcp dst-port=53 log=yes
      log-prefix="DNSREQ"
 9    chain=dstnat action=dst-nat to-addresses=192.168.2.1 to-ports=53 protocol=udp dst-port=53 log=yes
      log-prefix="DNSREQ"
10 XI  chain=srcnat action=masquerade src-address-list=no-web-proxy log=no log-prefix=""
11 XI  ;;; Transparent HTTP proxy
      chain=dstnat action=redirect to-ports=8080 protocol=tcp dst-port=80 connection-mark=bypass_local_proxy log=no
      log-prefix=""
12 XI  chain=dstnat action=dst-nat to-addresses=192.168.3.10 to-ports=8080 protocol=tcp in-interface=bridge-local
      dst-port=80 connection-mark=TProxy_Target log=no log-prefix=""
13 XI  ;;; Masquerade for others - via MitraisVPN
      chain=srcnat action=masquerade out-interface=pptp-out-mitrais out-bridge-port=ether3-LAN log=no log-prefix=""
14 XI  ;;; Masquerade for others - via VPNBook
      chain=srcnat action=masquerade out-interface=VPNGate-OVPN log=no log-prefix=""
15 XI  chain=srcnat action=masquerade out-interface=SuperVPN-Germany log=no log-prefix=""
16    ;;; Masquerade for others - via Default Provider
      chain=srcnat action=masquerade out-interface=ether1-Public-1 log=no log-prefix=""
Mangle
[admin@redmond] /ip firewall> mangle print
      chain=prerouting
 1  D ;;; special dummy rule to show fasttrack counters
      chain=forward
 2  D ;;; special dummy rule to show fasttrack counters
      chain=postrouting
 3 XI  ;;; Mark traffic via unlocator
      chain=prerouting action=add-dst-to-address-list protocol=tcp address-list=no-web-proxy address-list-timeout=0s
      layer7-protocol=WhiteList dst-port=80 log=no log-prefix=""
 4 XI  chain=prerouting action=accept protocol=tcp src-address=192.168.2.107 in-interface=bridge-local log=yes
      log-prefix="tracking"
 5    chain=prerouting action=mark-connection new-connection-mark=USA-Limited passthrough=yes protocol=tcp
      dst-address=8.8.8.8 dst-port=53 log=no log-prefix="dns88"
 6    chain=prerouting action=mark-connection new-connection-mark=USA-Limited passthrough=yes protocol=udp
 7    chain=prerouting action=mark-connection new-connection-mark=USA-Limited passthrough=yes protocol=tcp
      dst-address=8.8.4.4 dst-port=53 log=no log-prefix="dns88"
 8    chain=prerouting action=mark-connection new-connection-mark=USA-Limited passthrough=yes protocol=udp
 9    chain=prerouting action=mark-connection new-connection-mark=USA-Limited passthrough=no protocol=tcp
      src-address=192.168.3.10 dst-port=53 log=yes log-prefix="se"
10    chain=prerouting action=mark-connection new-connection-mark=USA-Limited passthrough=yes protocol=tcp
      layer7-protocol=USA-Limited-L7 dst-port=53 log=no log-prefix=""
11    chain=prerouting action=mark-connection new-connection-mark=USA-Limited passthrough=no protocol=udp
12    chain=prerouting action=mark-connection new-connection-mark=USA-Limited passthrough=yes protocol=udp
13 XI  chain=prerouting action=mark-connection new-connection-mark=gameport passthrough=yes protocol=tcp
      dst-port=5222-5228 log=no log-prefix=""
14 XI  chain=prerouting action=mark-connection new-connection-mark=gameport passthrough=yes protocol=udp dst-port=17003
15 XI  ;;; Mitrais DNS
      chain=prerouting action=mark-routing new-routing-mark=via-Mitrais-VPN passthrough=yes protocol=tcp
      layer7-protocol=Mitrais route dst-port=53 log=no log-prefix=""
16 XI  chain=prerouting action=mark-routing new-routing-mark=via-Mitrais-VPN passthrough=yes protocol=udp
17 XI  chain=prerouting action=mark-routing new-routing-mark=VPNBook-Routing passthrough=yes log=no lo
18 XI  chain=prerouting action=mark-connection new-connection-mark=Youtube-Conn passthrough=yes layer7
19 XI  ;;; Cache HIT
      chain=output action=mark-packet new-packet-mark=cache-hits passthrough=no dscp=4 log=no log-pref
20    chain=prerouting action=mark-routing new-routing-mark=viaProxy passthrough=yes protocol=tcp
      in-interface=bridge-local dst-port=80 log=no log-prefix=""
21    chain=prerouting action=mark-routing new-routing-mark=viaProxy passthrough=yes protocol=tcp
      in-interface=bridge-segment-3 dst-port=80 log=no log-prefix=""
22 XI  chain=prerouting action=mark-routing new-routing-mark=viaProxy passthrough=yes protocol=tcp
      in-interface=bridge-local dst-port=443 log=no log-prefix=""
23 XI  chain=prerouting action=mark-routing new-routing-mark=viaProxy passthrough=yes protocol=tcp
      in-interface=bridge-segment-3 dst-port=443 log=no log-prefix=""
24    chain=prerouting action=mark-connection new-connection-mark=TProxy_Target passthrough=yes protoc
you have a ;
Forward LAN >> WAN
chain=forward action=accept out-interface=ether1-Public-1 log=no log-prefix=“”
you need a
; Forward LAN1 >> LAN2
chain=forward action=accept out-interface=LAN-1 log=no log-prefix=“”
and
Forward LAN2 >> LAN1
chain=forward action=accept out-interface=LAN-2 log=no log-prefix=“”
Thanks you save my day.
