This is not enough information for anybody to help you. Are other applications working? Do clients have internet access? What is the overall system layout?
Actually i am really new in mikrotik, the network person who used to configure mikrotik has resigned and unfortunately things come upto me.
What we are running right now in our mikrotik, is just proxy server. We have two interface card in our mikrotik server,
1- Lan
2- Wan
nothing else running on it.
I dont know how to configure nat, but i will read the topic provided by docmarius.
Outlook has more than one way of accessing an Exchange server so make sure that you know which method (and therefore which ports) are necessary for your clients.
Checking your client settings and some Google should make it clear.
Some forward firewall rules to allow forwarding, in IP/Firewall/Filter:
add action=accept chain=forward comment="Forward from ISP" in-interface=WAN
add action=accept chain=forward comment="Forward to ISP" in-interface=LAN
Now ALL your connections should work, including outlook.
If you really need webproxy, you can enable it AFTER this works.
Of course you can also use Winbox to set up these rules.
If you use programs like Skype or uTorrent which support automatic firewall pass-through and want them to be able to accept direct WAN connections, you can enable UPNP under IP/UPnP, which will give you automatic dstnat rules.
i have walled garden ports 993,995,465 for outlook can download yahoo business email & attachments using full line speed (8 MB )without users having to logon to hotspot & it works great, but once a user login email download speed drops down to user’s limit (eg.: 512KB) & it fails many times giving error message (connection to server is interrupted) or (couldn’t download some messages )
when i disable hotspot or kick the user out or make bindings for a PC it works great but users will use internet with unlimited speed which causes many problems
a user in this forum told me to to mark outlook traffic & use simple queue for outlook but it’s getting bypassed by hotspot sever & users’ dynamic queues
it’s ROS 5.18 but can’t upgrade now for many reasons
I think it’s hotspot problem or it may be
I’ve 2 Lines ( real ADSL IPs) divided for 2 IP ranges using NAT mark routing & masquerade, hotspot , DHCP thats all
realy appreciate any help possible
