how to allow pptp at firewall
hi all,
i try make firewall to allow pptp connection, i have turn on gre and pptp at service port. then i make firewall to allowed pptp connection to this router. this my firewall configuration :
0 ;;; Checked For Viruses Port
chain=input action=jump jump-target=virus
1 chain=forward action=jump jump-target=virus
2 ;;; allow ping
chain=input protocol=icmp action=accept
3 chain=forward protocol=icmp action=accept
4 ;;; Accept established connections
chain=input connection-state=established action=accept
5 chain=forward connection-state=established action=accept
6 ;;; Accept related connections
chain=input connection-state=related action=accept
7 chain=forward connection-state=related action=accept
8 ;;; Drop invalid connections
chain=input connection-state=invalid action=drop
9 chain=forward connection-state=invalid action=drop
10 ;;; From All Network
chain=forward src-address-list=Allowed action=accept
11 ;;; To All Network
chain=forward dst-address-list=Allowed action=accept
12 ;;; Allowed PPPtP
chain=input protocol=tcp dst-port=1723 action=accept
13 chain=input protocol=tcp dst-port=47 action=accept
14 ;;; Port scanners to list
chain=input protocol=tcp psd=21,3s,3,1 action=add-src-to-address-list
address-list=port scanners address-list-timeout=2w
15 chain=forward protocol=tcp psd=21,3s,3,1 action=add-src-to-address-list
16 ;;; NMAP FIN Stealth scan
chain=input protocol=tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg
action=add-src-to-address-list address-list=port scanners
17 chain=forward protocol=tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg
18 ;;; SYN/FIN scan
chain=input protocol=tcp tcp-flags=fin,syn
19 chain=forward protocol=tcp tcp-flags=fin,syn
20 ;;; SYN/RST scan
chain=input protocol=tcp tcp-flags=syn,rst
21 chain=forward protocol=tcp tcp-flags=syn,rst
22 ;;; FIN/PSH/URG scan
chain=input protocol=tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack
23 chain=forward protocol=tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack
24 ;;; ALL/ALL scan
chain=input protocol=tcp tcp-flags=fin,syn,rst,psh,ack,urg
25 chain=forward protocol=tcp tcp-flags=fin,syn,rst,psh,ack,urg
26 ;;; dropping port scanners
chain=input src-address-list=port scanners action=drop
27 chain=forward src-address-list=port scanners action=drop
28 ;;; Drop everything else
chain=input action=drop
29 chain=forward action=drop
with this rule, pptp conenction still drop. please share
The error is in your second PPTP rule. You have to allow ip PROTOCOL 47 (GRE), not TCP port 47.
So this should be
13 chain=input protocol=47 action=accept
TCP port 1723 is the control connection, while the actual tunnel is GRE (protocol 47).
Best regards,
Christian Meis
ive always wondered, is that rule the same as enabling the gre and pptp option in winbox under IP->FIrewall->service ports?
which one superciddes the other? (ie if i have it set to disable gre in FW but enabled in winbox service ports?)
tks
The service ports in the firewall section are only needed for traversing NAT.
So there’s not one taking priority over the other - those are two different things.
Best regards,
Christian Meis
GRE how can use key?
So there’s not one taking priority over the other - those are two different things???
WALEEEED
-== crossword puzzles ==
