How to allow restricted connection from guest network to lan
Hi, I’m Mikrotik newbie and I need advice. I have Mikrotik router managing my local network (both wired and wireless). I would like to create separated wireless network (similar to guest network) but with manually specified allowed connections from LAN.
Motivation is that in restricted networks are devices that I don’t trust but I need to access them from the PC at specific IP and specific port.
What is the simplest way how to achieve this configuration? I was originally thinking about firewall rules inside LAN but they don’t seem to work.
Thanks for any advice
Tom
Typically we use vlans to separate subnets. This takes care of clear separation at layer 2 and we use firewall rules to separate at layer 3 ( prevent router from routing between subnets since it knows they exist and where they exist).
Also its quite normal for vlan to share a printer that is on a guest or trusted network.
So if you wish to allow ONE pc in a trusted network to reach a bunch of devices in other subnet you have many options, depending upon how anal one is . :slight_smile:
Simple
add chain=forward action=accept in-interface=VLANX srcr-address=ONEPC dst-address=subnetwithDevices
one pc has full access to an untrusted network.
add chain=forward action=accept in-interface=VLANX src-address=ONEPC dst-address-list=Devices
one pc has access to a list of devices on an untrusted network
add chain=forward action=accept in-interface=VLANX src-address=ONEPC dst-address-list=Devices dst-port=XXXXX
one pc has access to a specific port to a list of devices on an untrusted network.
/ip firewall address-list
add address=device1 list=Devices
add address=device2 list=Devices
add address=devicen list=Devices etc…
Thanks a lot for your answer.
I created guest network using Quick Set. I guess approach suggested by you will not work as Quick Set doesn’t use VLAN approach for defining guest networks. Am I right?
So should I remove guest wifi and define it manually using VLAN and then use ip/firewall rules?
I tried to use Bridge/Filter to forward traffic from IP to IP but with no luck.
I’m also attaching my configuration as it may help you to understand my configuration (mostly created by Quick Set).
# jul/30/2024 12:26:58 by RouterOS 6.49.6
# software id = XWMA-3FDC
# model = RBD52G-5HacD2HnD
# serial number = BEEB0B5128A2
add admin-mac=C4:AD:34:57:ED:AD auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country="czech republic" disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-57EDB1 \
    wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country="czech republic" disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-57EDB1 \
/interface vlan
add interface=ether1 name=vlan-848 vlan-id=848
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan-848 keepalive-timeout=disabled max-mru=1492 max-mtu=1492 name=pppoe-nordic user=nordic
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk group-ciphers=tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik unicast-ciphers=tkip,aes-ccm
add authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys name=profile supplicant-identity=MikroTik
/interface wireless
add disabled=no mac-address=C6:AD:34:57:ED:B2 master-interface=wlan2 name=wlan3 security-profile=profile ssid=Mikrotik_guest
add disabled=no mac-address=C6:AD:34:57:ED:B1 master-interface=wlan1 name=wlan4 security-profile=profile ssid=Mikrotik_guest
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/interface bridge filter
add action=drop chain=forward in-interface=wlan3
add action=drop chain=forward out-interface=wlan3
add action=drop chain=forward in-interface=wlan4
add action=drop chain=forward out-interface=wlan4
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=wlan3
add bridge=bridge interface=wlan4
add interface=*E
/interface detect-internet
set detect-interface-list=all
/interface wireless access-list
add comment=Thea interface=wlan4 mac-address=A4:50:46:57:1A:E9
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.88.240 mac-address=E0:D5:5E:DA:17:59 server=defconf
add address=192.168.88.250 client-id=1:d0:27:24:0:77:6d mac-address=D0:27:24:00:77:6D server=defconf
add address=192.168.88.230 mac-address=40:8D:5C:CD:8D:7A server=defconf
add address=192.168.88.220 client-id=1:ac:84:c6:27:f7:6 mac-address=AC:84:C6:27:F7:06 server=defconf
add address=192.168.88.210 client-id=1:9c:ae:d3:1:85:1b mac-address=9C:AE:D3:01:85:1B server=defconf
add address=192.168.88.200 client-id=1:0:8:9b:c1:e5:d6 mac-address=00:08:9B:C1:E5:D6 server=defconf
add address=192.168.88.190 client-id=1:d8:3a:dd:2c:25:e6 mac-address=D8:3A:DD:2C:25:E6 server=defconf
add address=192.168.88.100 client-id=1:fc:ee:28:3:4d:5e comment="K1C Tisk\E1rna" mac-address=FC:EE:28:03:4D:5E server=defconf
add address=192.168.88.180 client-id=1:14:98:77:47:a3:0 mac-address=14:98:77:47:A3:00 server=defconf
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.20 comment="Tisk\E1rna" list=restricted_devices
add address=192.168.88.120 comment="Notebook docasne" list=restricted_devices
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes ipsec-policy=out,none out-interface-list=WAN
add action=masquerade chain=srcnat out-interface=pppoe-nordic
/system clock
set time-zone-name=Europe/Prague
/system logging
add topics=dhcp
add topics=wireless
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-interface=*D
Thanks a lot for your help
Tom
