does anyone how works activity? On one router I can see activities and on another I can not see any activity, How to allow to see actiity?
You need to specify a name and time interval for the function to become active.
E.g. you can add one entry like this:
/ip kid-control
add fri=0s-1d mon=0s-1d name=any sat=0s-1d sun=0s-1d thu=0s-1d tue=0s-1d wed=0s-1d
then it will start to collect the activity of all users, without limiting it at first.
Thank you.
I have used your script and it is not showing anything yet. I hope the data will show soon.
BTW what is system dummy as default there?
Hardware offload or fasttrack do not show any on kid control.
The second router is inside same network or is on another house?
In the kid control there is default name system -dummy I did not create this I have it on both routers.
I have two separate routers and after add entry the activity is not showing anything I even tried to restart router. Both routers are running ROS 7.5
Any idea why one is showing activity and another not?
No. It works for me, and you do not show the configs.
Maybe post a drawing of your network showing both routers. Traffic needs to pass a router for kid control to give any data.
Yeah, when one of the routers is configured as a bridge (effectively a switch) it will not work.
The routers I have where there is a real routing function work fine.
Those routers are on different places and both are routing.
All novels, no /export
Please see my config and let me know where could be problem…
# oct/30/2022 21:36:28 by RouterOS 7.6
# software id = D7SA-MDTW
# model = RBD53iG-5HacD2HnD
# serial number =
/disk
set usb1-part1 name=disk3
add admin-mac=2C:C8 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=04:
set [ find default-name=ether5 ] poe-out=off
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=2ghz-n .width=20mhz \
configuration.mode=ap .ssid=MATRIX .tx-power=40 disabled=no mtu=1500 \
name=MATRIX security.authentication-types=wpa-psk,wpa2-psk .ft=yes \
.ft-over-ds=yes .group-encryption=tkip .management-protection=allowed
set [ find default-name=wifi2 ] channel.band=5ghz-ac .frequency="" \
.secondary-frequency="" .skip-dfs-channels=all .width=20/40/80mhz \
configuration.country=Czech .mode=ap .ssid=MATRIX disabled=no mtu=1500 \
name="MATRIX 5G" security.authentication-types=wpa-psk,wpa2-psk \
.encryption="" .ft=yes .ft-over-ds=yes .management-protection=allowed
/interface wireguard
add disabled=yes listen-port=22 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
/interface wifiwave2 security
add authentication-types=wpa-psk,wpa2-psk ft=yes management-protection=\
allowed name=sec1
/ip kid-control
add fri=0s-1d mon=0s-1d name=any sat=0s-1d sun=0s-1d thu=0s-1d tue=0s-1d wed=\
0s-1d
add name=pool1 ranges=192.168.1.10-192.168.1.254
add address-pool=pool1 interface=bridge lease-time=4w2d23h59m name=defconf
/queue type
add cake-ack-filter=filter cake-diffserv=besteffort cake-nat=yes kind=cake \
name=CAKE
/queue simple
add bucket-size=0.001/0.001 limit-at=100M/22M max-limit=300M/22M name=Cake \
queue=CAKE/CAKE target=ether1 total-queue=CAKE
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=yes name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/zerotier
set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" \
identity="" name=zt1 \
port=9993
/zerotier interface
add instance=zt1 name=zerotier1 network=35c192ce9bdf2969
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge ingress-filtering=no interface=ether2
add bridge=bridge interface="MATRIX 5G"
add bridge=bridge interface=MATRIX
add bridge=bridge interface=*10
add bridge=bridge interface=*11
set discover-interface-list=all lldp-med-net-policy-vlan=1
/ipv6 settings
/interface detect-internet
set detect-interface-list=all
add interface=wireguard1 list=LAN
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
192.168.1.0
add address=10.255.255.2/30 interface=wireguard1 network=10.255.255.0
/ip dhcp-client
add default-route-distance=2 interface=ether1 use-peer-dns=no
/ip dhcp-server lease
add address=192.168.1.11 client-id=1:24:5e:be:48:ae:c4 comment=QNAP \
mac-address=24:5E:BE:48:AE:C4 server=defconf
add address=192.168.1.12 client-id=1:d4:b7:61:6c:95:bd comment=Kamera \
mac-address=D4:B7:61:6C:95:BD server=defconf
add address=192.168.1.19 client-id=1:4c:2:20:64:56:51 comment="Asi Verka" \
mac-address=4C:02:20:64:56:51 server=defconf
add address=192.168.1.20 client-id=1:3a:e1:f3:4c:3b:45 comment=iPhone \
mac-address=3A:E1:F3:4C:3B:45 server=defconf
add address=192.168.1.17 client-id=1:b0:e4:d5:b9:7c:cc mac-address=\
B0:E4:D5:B9:7C:CC server=defconf
add address=192.168.1.13 mac-address=54:48:E6:29:CE:FE server=defconf
add address=192.168.1.21 mac-address=54:48:E6:41:36:0A server=defconf
add address=192.168.1.15 client-id=1:6c:88:14:65:29:5c mac-address=\
6C:88:14:65:29:5C server=defconf
add address=192.168.1.22 client-id=1:64:bc:58:ec:82:59 comment="HR notebook" \
mac-address=64:BC:58:EC:82:59 server=defconf
add address=192.168.1.10 client-id=1:fc:3:9f:2:98:5e comment="Samsung TV" \
mac-address=FC:03:9F:02:98:5E server=defconf
add address=192.168.1.14 client-id=1:c8:e2:65:45:78:a6 mac-address=\
C8:E2:65:45:78:A6 server=defconf
add address=192.168.1.23 client-id=1:84:c5:a6:9c:21:bf mac-address=\
84:C5:A6:9C:21:BF server=defconf
add address=192.168.1.25 client-id=1:d4:86:60:32:6b:18 comment="LG TV" \
mac-address=D4:86:60:32:6B:18 server=defconf
add address=192.168.1.35 client-id=1:1c:69:7a:68:a5:4d mac-address=\
1C:69:7A:68:A5:4D server=defconf
add address=192.168.1.36 client-id=1:dc:a6:32:a1:d0:17 mac-address=\
DC:A6:32:A1:D0:17 server=defconf
add address=192.168.1.16 client-id=1:6e:ff:20:ee:7b:f0 comment=OnePlus9 \
mac-address=6E:FF:20:EE:7B:F0 server=defconf
add address=192.168.1.24 client-id=1:c2:dd:5d:f:9b:c6 comment=Verka \
mac-address=C2:DD:5D:0F:9B:C6 server=defconf
add address=192.168.1.0/24 comment=defconf dns-server=8.8.8.8 gateway=\
192.168.1.1
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1
/ip dns static
add action=jump chain=forward comment="jump to kid-control rules" \
jump-target=kid-control
add action=drop chain=forward comment="HWC-P120 Adamek" disabled=yes \
src-address=192.168.1.12
add action=accept chain=input dst-port=22 protocol=udp src-address=\
185.5.225.240 src-port=""
add action=accept chain=forward in-interface=zerotier1
add action=accept chain=input in-interface=zerotier1
established,related,untracked
invalid
"defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
dst-address=127.0.0.1
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=established,related disabled=yes hw-offload=yes
connection-state=invalid
/ip kid-control device
add mac-address=54:48:E6:29:CE:FE name=device1 user=*3
add mac-address=54:48:E6:41:36:0A name=device2 user=*4
add disabled=no dst-address=10.1.168.0/24 gateway=wireguard1 routing-table=\
main suppress-hw-offload=no
/ip smb
set domain=workgroup
/ip smb shares
add directory=/disk1 name=share1
/ip upnp
set show-dummy-rule=no
/snmp
set enabled=yes
/system clock
set time-zone-name=Europe/Prague
/system identity
set name=TAPAC3
/system logging
add disabled=yes topics=wireguard
/tool graphing interface
add
/tool graphing resource
add
/tool mac-server
/tool mac-server mac-winbox
/tool netwatch
add disabled=no down-script=":log error \"Ping to 8.8.8.8 LOST\"" host=\
8.8.8.8 interval=1m timeout=100ms type=simple up-script=\
":log error \"Ping to 8.8.8.8 OK\""
/tool romon
set enabled=yes
h
Hello Rextended,
do you have please any idea?
Not sure what this could give.
add action=jump chain=forward comment="jump to kid-control rules" jump-target=kid-control
This firewall rule tells that it should jump to kid-control chain, but I do not see any rules with chain=kid-control
That should not matter… remember it is called “jump” but it actually is “call”. When there are no rules in that chain the default is to return to the next statement.
