How to appear as blackhole on internet on PPOE
I have a PPOE internet connection. I have written several rules to drop packets when aimed at port 21, 22, 80, 443, 8291 TCP etc. They remain unresponsive, yet when I do an nmap from another host the ports are listed as ‘filtered’ and they all get listed. I would rather nothing showed. Any ideas?
chain=input action=drop protocol=tcp in-interface=pppoe-out1 dst-port=80
log=no log-prefix=“”
I also want to disable a ping response, but I must be doing something wrong.
chain=input action=reject reject-with=icmp-host-unreachable
protocol=icmp log=no log-prefix=“”
I want my device not to be at all visible from the outside, yet, I want to be able to connect to my LAN via PPTP or IPSEC. I have the PPTP server working fine on port 1723.
Also, the internet connection comes in on ether1, should I be using this or pppoe-out1 as the device?
Sorry, I know they are elementary questions. Any advice gratefully received.
Just set your firewall up like this:
add chain=input action=accept connection-state=established,related
add chain=input action=icmp action=accept
add chain=input protocol=tcp dst-port=1723 action=accept comment="allow pptp connections"
add chain=input in-interface=pppoe1-out action=drop
This is a default-drop on the WAN (use the pppoe interface, not the physical interface, because the physical interface isn’t doing IP - it’s just transporting pppoe-encapsulated ethernet frames, so any rule referring to the physical interface won’t work). This will not generate any connection refused type of messages for scanners to see.
Personally, though, I’d allow icmp (as my suggested rule chain does). Who cares if they can ping it but nothing else? being “unpingable” is just security through obscurity which doesn’t do anything anyway. Furthermore, there are certain ICMP messages that you want to receive, and just throwing it all into the trash is a dubious “best practice” of yesteryear. Modern scans don’t care if you’re pingable - they just look for the ports they want to exploit.
And I have news for you - because your PPTP port is allowed, your box is now no longer invisible. The scanners WILL find this port.
Thank you very much for the prompt reply!
I realise you can’t hide, but if you don’t make ports obvious, I would imagine you are reducing the interest. I am trying to learn from this.
Your script has a couple of errors
syntax error (line 1 column 24)
input does not match any value of interface
Any thoughts?
