How to Apply Different Treatment for Overseas Traffic
Since we’re not allowed to use older versions of Mikrotik I would like to know if the article on this page:
http://www.mikrotik.com/docs/ros/2.8/howto/howto.content
is still applicable to RouterOS 2.9.
It is possible to recreate the similar configuration as described in the documentation, but you will have to set appropriate syntax.
But 2.9 introduced new option address-list, you may search in the forum, the same topic was discussed few times.
Thank you I believe I have found the item you are referring to:
http://forum.mikrotik.com/t/overseas-traffic-in-2-9-26/7888/1
