how to assign 2 Private IP address
[b][b] hi guys … how to assign 2 different Private IP address on 2 Ports for example : 192.168.0.1 & 172.31.0.1 and each port of them distribute DHCP
moreover both of them not allow to access each other how do that step by step???
thank you in advance :smiley: [/b][/b]
Assign the Addresses to the respective ports
Create a DHCP server on each port to distribute addresses in the relevant range
Create a firewall rule to drop traffic from each lan trying to access the other.
Just choose the port and assign the ip address. make sure the interfaces are not bridged. Run dhcp i each of the port and make sure ur firewall rules does not permit each other ip to access another.
Just choose the port and assign the ip address. make sure the interfaces are not bridged. Run dhcp in each of the port and make sure ur firewall rules does not permit each other ip to access another.
