How to assign profiles to users??
I’m confused about how to assign a profile made in new user manager to users?
also it will be best if mac address is taken automatically from users pc at first login
I’m setting up a new network please help me!
Hi Asus.
Asus you have to make profiles if you are using HotSpot or PPPoE services.
The name of the user profile you created you have to put that name on the Group when you crate new user on User Manager.
Example: put the name on user profile 512 and this number put on the group 512 but don’t forget to put the bits rate on the tx/rx rate when you creating profile.
Let me know if this help you a little bit.
thx
Selim
I asume, Asus is talking about the beta release. It is not possible to assign profiles to users in the current beta (GUI is not implemented for this operation) but it will be available in the next release.
thanks alot
