How to autodiscover mikrotik
How I can autodiscover mikrotik in my lan? It’s an UPD? witch format?
I want to develope a little application by my self, like NeighborViewer, that retrieve informations about all mikrotik in the lan.
just use the dude
ok…but if I want to develope a personal application?
you can use ping, snmpwalk and other tools to discover devices and services
but how can I be shure about to find mikrotik?
OK, let me pick that up. :smiley:
I can see roughly what’s happening when you press the “…” button in the WinBox connection dialog (broadcasts, …) using a packet sniffer.
Would MikroTik open up the details of the possible responses of RouterOS devices?
Best regards,
Christian Meis
Yes, something like that.
MT uses CDP (Cisco Discovery Protocol), described in full at http://www.cisco.com/univercd/cc/td/doc/product/lan/trsrb/cisnm.htm
C
Banging … my … head … on … the … wall …
Thanks! Of course - that was to expect, as I can see our Ciscos with it :smiley:
Best regards,
Christian Meis
BUT…
using CDP Monitor software we cannot scan MT.
IP->Neighbours, and enable the discovery interfaces.
They are enables. Simultaneously checking with Neighbor viewer shows MT. But with any other CDP MONITOR software MT is not discovered. I think MT is not 100% CDP.
Works fine for me,
root@netsphere:~# cdpr
cdpr - Cisco Discovery Protocol Reporter
Version 2.2.0
Copyright (c) 2002-2004 - MonkeyMental.com
1. sis0 (No description available)
2. rl0 (No description available)
3. lo0 (No description available)
Enter the interface number (1-3):1
Using Device: sis0
Waiting for CDP advertisement:
(default config is to transmit CDP packets every 60 seconds)
Device ID
  value:  mikrotik-core02
Addresses
  value:  198.18.0.35
That’s a CDP client on Unix picking up my mikrotik box. You don’t perhaps have some firewalls somewhere dropping the packets?
I am using CDP Monitor from TALLSOFT. It works on WINDOWS XP. It doesn’t show. Do you know any software which works on Windows and can scan MT. I don’t want to use Neighbor Viewer for some reason.
Windows? unfortunately not.
Keep in mind, it is very possible that the firewall in SP2 may block this traffic…
