have many mikrotiks with private addresses which act as a nat. However I have several network prefixes (all in my own network) I don’t want to nat the traffic to.
I have done it making /ip firewall address-list nonat and defining there some prefixes and one rule in /ip firewall nat which accepts dst-addresses in nonat address-list and then src-nat is done to other addresses.
Everything is fine but the prefixes I don’t want to nat change - some network connects and they join the list, some disconnect and they are removed.
Is there a way to automate changing the configuration od 20 mikrotiks?
All 20 mikrotiks have the same /ip firewall address-list nonat and all I want to do is to somehow automate the process of updating the list. It doesn’t not to be immidiately, for example the update (if needed) once an hour is OK.
I have thought to put some file on web and that file has all prefixes listed.
Once an hour Mikrotiks downloads the file, update the firewall address-list.
Is it possible to do it?
Better run a bash script from dedicated box, something like:
for i in $ROUTER_ADDRESSES do
ssh -l $USER $i “/ip firewall address-list rem [find name=nonat]; /ip firewall address-list add name=nonat address=”;
done
Yes, I know such solutions - they are good but have one weak point - after compromising one “dedicated box” all my mikrotiks stay open. That is why I prefer web data fetching.
I think he/she means that doing a pull from each router (each with their own security) is more secure than pushing from a single location, because if that single location gets compromised they gain access to all the boxes.
I will also echo the request for wget, or even better curl.
One avenue you may wish to explore, would be linking a BGP instance to the address-list(s), with a frequently run script (I use a funky ping, and a firewall rule that detects it, to avoid writing to flash, and to ensure the address ages out correctly). That way, you could keep them updated in near real-time, and a compromise of your route server would only give access to the address-list(s) under it’s control. I’ve been playing with something like this, and it does work, but I haven’t actually used it for anything yet.
I’m not sure if I have understood - do you suggest that I make bgp route server and announce there routes which I don’t want to nat?
And then script on mikrotik which searches for routes received and adds them to firewall address-list?
I am sure I will find a use for having the MT produce the pings to add rules though, so I’m glad you posted that. I have internal web servers using that ping method to add blocks to the firewalls on the fly, just found more uses for your scripts above : )
The major difference is that the bogon one modifies the config, and does not break on non-/32 routes; while the ping-based one is just the opposite. I wanted to avoid modifying the config, and take advantage of the address-list-timeout option. But, you can’t ping a /24 as a whole; and if it looped through sending pings to each address, as the address-list could grow huge and inefficient.
I suppose one could make a hybrid, where it would ping if a /32, and manually add if not, but that could be confusing (and inconsistent in it’s timeout method).
Slightly different tools for slightly different tasks, I guess.
Unless, of course, MT wanted to add a direct path between BGP and address-lists, bypassing the need for a script entirely. Something like:
That would be handy. Being able to use address-list for BGP annoucements / filters would be nice : ) We plan on providing BGP feeds as a public service shortly… subscribe to a feed of known zombies, port scanners, rbls, etc. Somewhat like the Cymru bogons bgp feed. It would be nice to use mikrotik for this.
No, becouse we can filter pulled data. Some checking can be done. Some damage can be done if main box is compromised (for example they can turn off nat for everyone), but they can not compromise the rest of boxes, for example they can not steal data from them.
Haha, wget would be cool but consider if someone compromises the webserving server?
Talk about shooting yourself in the foot.
And injecting text into http tcp connections is among the easier things to do with . All the hacker would need to be doing is be connected to the same bridged/switched/hubbed network. Doesn’t have to be the same access point event!
Hi Gregor, not sure if you found a decent solution but… you could try http://www.routertools.com.au. We wrote this software after trying to manage 400 routers became near impossible doing it 1 by 1.
