I have a Mikrotik hAP ax2 which I mainly use for wireless access when travelling. My goal is to connect the router to the hotel wifi and act as an access point for all of my own devices. At this point I have the 2.4 GHz radio connected to the hotel wifi in station mode and I have created an access point using the 5 GHz radio.
My question is if it would be possible to create a list of known wifi networks (SSID & passphrase) which the router automatically connects to if any of the networks have been found to be accessible? If I am travelling between known locations (and networks) this would make it much easier to setup the router without the need to log in and reconfigure the station mode.
My configuration is as follows:
# 2024-05-17 00:00:20 by RouterOS 7.14.3
# software id = EX3R-84KS
# model = C52iG-5HaxD2HaxD
add admin-mac=00:00:00:00:00:00 auto-mac=no name=bridge-LAN port-cost-mode=\
short
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi datapath
add bridge=bridge-LAN disabled=no name=datapath-LAN
add disabled=no interface-list=WAN name=datapath-WAN
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ac .width=20/40mhz-Ce \
configuration.mode=ap .ssid=wifi-AP datapath=\
datapath-LAN disabled=no mtu=1500 name="wifi1A-AP (5GHz)" \
security.authentication-types=wpa3-psk .wps=disable
/interface wifi configuration
add datapath=datapath-WAN disabled=no mode=station name=\
network1 security.wps=disable ssid=network1
/interface wifi
set [ find default-name=wifi2 ] configuration=network1 \
configuration.mode=station disabled=no name="wifi2A-CLIENT (2 GHz)"
add name=dhcp-pool-0 ranges=10.20.0.10-10.20.0.254
add address-pool=dhcp-pool-0 interface=bridge-LAN lease-time=1d name=\
dhcp-server-0
/ip smb users
add bridge=bridge-LAN interface=ether2
add bridge=bridge-LAN interface=ether3
add bridge=bridge-LAN interface=ether4
add bridge=bridge-LAN interface=ether5
set udp-timeout=10s
add interface=ether1 list=WAN
add interface=bridge-LAN list=LAN
add interface=*B list=LAN
add address=10.20.0.1/24 interface=bridge-LAN network=10.20.0.0
/ip cloud
set update-time=no
/ip dhcp-client
add interface="wifi2A-CLIENT (2 GHz)"
add address=10.20.0.0/24 dns-server=10.20.0.1 gateway=10.20.0.1
set allow-remote-requests=yes
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface-list=\
WAN
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip smb shares
set [ find default=yes ] directory=/pub
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Rome
/system identity
set name=RemoteRouter
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=pool.ntp.org
/tool mac-server
/tool mac-server mac-winbox
