i need to backup my arp entry, queue, firewall, ect. i creat backup with winbox backup option but when i restore it to another system. i got nothing. so i can i creat backup ?
copy the backup file and then upload to other box if u want
Hello friend,
Better, you will save your backup file, with export file action. and before uploading you must edit little by text [notepad] mac address[es] of your interface. cause you will move to other interface.
this CLI command
/export file=backup
after this command, download this file. and will give you backup.rsc filename on your router list table file
regards
Hasbullah.com
The backup command stores the MAC addresses of the Ethernet ports which are unique to the router. Restoring this onto new or other hardware will result in a mismatch of addresses and the restore won’t work.
Better to export and then apply the settings.
you can read from this web http://mikrotik.unimedcenter.org/back-up-and-restore-the-mikrotik
