Your only real option is to isolate the users on the layer2 network. When two users talk to each other on the same layer2 network, they need not use the router to get to each other, and therefore they don’t. No amount of firewall rules/blocking will do anything to prevent that since the traffic never flows over the router. This means you need to buy hardware that the guests connect to that supports this functionality.
Yes it is possible, but only depending on your setup.
If you are using wiresless, set client isolation (disable default forwarding on mikrotik wireless). If you are using the inbuilt mikrotik ethernet ports, use bridge horizons or firewall rules.
If you are expanond the wired network, use managed L2 switches, using port isolation or make every port a different vlan and trunk back to the mikrotik and use bridge horizons..
