Hi !
I’m new to that product. i was able to make internet working easily, but i would like to be able to setup a hotspot (username and password) and only allow one site.
Could it be possible to get a step by step setup ??
Thank you for your help !!!
Hi !
Yes of cause there is a step-by-step HOWTO in the Wiki or “online manual”
HotSpot
HotSpotServer
Customizing Hotspot
Hotspot Introduction
I think this should be enough for you to read and test it out!
Good luck
Thank’s, but that does not work !!! There must be something i dont understand !!??
My router seem to work fine. Hotspot and website block is ok. But i have another question, since the hotspot is configure, ethernet port wont go trough to go on internet. Is this normal ?
Do i need to configure something else !??
