Dears…
how to block any site that ends with free subdomain hosting
for ex: *.biz
Regards,
Dears…
for ex: *.biz
Regards,
http://wiki.mikrotik.com/wiki/Manual:IP/Proxy
http://wiki.mikrotik.com/wiki/How_to_make_transparent_web_proxy
you have more links about mikrotik web proxy on the Internet
Also remember, proxy will not work with HTTPS.
I can’t use web proxy… I have an external Cache
why you can’t use web proxy.
I have a special rules for traffic data between mikrotik & external cache…
look man you can do it through ur own proxy server, and you can do it through mikrotik webPROXY
through ur proxy server if you need to block downloading .biz
you can go to ur own proxy panel and block this path *.biz
through MIKROTIK WebPROXY you can do it by doing this steps:
1- Firewall > NAT > create new rule > chain: dstnat, protocol: 6 (tcp), dst-port: 80 > action: redirect to-ports:8080 .
2- IP> Web Proxy> Enable ( Check Mark On Enable ) > Port: 8080 > Access > Add New Rule > Path: *.biz > Action: Deny.
Good Luck
