I wanted to know how to block discovery with WinBox on some machine on my network
add action=drop chain=input disabled=no dst-port=8291 protocol=tcp src-address=!ip
Its working fine for IP but you can still connect by mac address
if i’m right you need to block (udp)5678.
i try this
add action=drop chain=input disabled=no dst-port=5678 protocol=tcp src-address=!ip "
its not working
i try to block this port but it not working
I think you are using the wrong protocol.
Change to this:
add action=drop chain=input disabled=no dst-port=5678 protocol=udp src-address=!ip
You can use the address list but I usually block this traffic based on inbound port.
Also have a look at the Tools-> MAC Server section.
Is your problem solved?
So “yes” can you tel how?
There is no need to write a rule.
IP / Neighbor List / discovery interface
disable all interfaces.
Also maybe you wanted to write a rule, I tried to block SSH
and it block discovery ![]()
This working indeed.
Many thanks
Is not working wich Mac address i put a good protocol (udp) and good port for discovery and Mac 20561, 5678
But its not working .
when I block the interface it work but I want to make rules
