How to Block Multiple login?
How can i block multiple login with same PPPoE user credential ? Any Help!!
are they all authenticated locally on one machine, or you use some kind of RADIUS?
if locally, in the “/ppp profile” that you use for these users, set “only-one=yes”
Users are authenticated through Radius..
a4ubd
in that case, see your RADIUS server documentation …
