how to block shared connection!!
how to block shared connection of my client?
If they use a router you really can’t. You could limit the amount of connections but that is really a crapshoot
This was discussed here some time ago. I guess the thread is archived somewhere.
If you check the TTL on packets coming from the network you can delete any that have already traversed a router as they will show a lower value.
Regards
Andrew
how can one check the TTL on packets coming from the network?
It can be done using Iptables…
http://www.linuxsecurity.com/resource_files/firewalls/IPTables-Tutorial/iptables-tutorial.html#TTLMATCH
But maybe some experts here can show us how you do that on RouterOS? Can it be done using RouterOS?
