Hello , I trying to block viber in routerboard (Mikrotik) but I can’t , I try to block port of viber and I seeing more and more port
and try to do block but not work , so rule in firewall is working but viber Still work
any one have solution to block viber in mikrotik, ?
regards
Have you tried to block VIBER with layer 7 firewall ?
#1. You can use Layer7 firewall to define sites or process you want to block. In your case VIBER
/ip firewall layer7-protocol add name=“VIBER” regexp=“^.(get|GET).+(viber).$”
#2. Create firewall mangle rule, to catch all connections from IP range you want to block access: (Change interface & address)
/ip firewall mangle add action=mark-connection chain=forward in-interface=<INTERFACE_NAME> new-connection-mark=VIBERc src-address=192.168.5.0/24
#3. Mark all packets from previos rule.
/ip firewall mangle add action=mark-packet chain=forward connection-mark=VIBERc new-packet-mark=VIBERpackets
#4. Drop all packets that contain Layer-7 rule and marked packets.
/ip firewall filter add action=drop chain=forward layer7-protocol=“VIBER” packet-mark=VIBERpackets
#Also only with layer7 you can’t block all viber connections, you can add rule, who looks in URL contents:
/ip firewall filter add action=drop chain=forward content=viber packet-mark=VIBERpackets
#Place both firewall filter rules on top of your firewall list !
Thanks for reply
I try this, but after setup method (config.) still viber working , plz help me
any method working? if you have more other method
regards
plz any one answer
