how to block vpn user access routeros?
how to block vpn user access routeros (winbox or web?)
Since it is a VPN user, it has a specific VPN pool right?
At least that how it should be…
Block the address of that VPN user for all the input traffic…
input chain in filter?
Yes…
input - used to process packets entering the router through one of the interfaces with the destination IP address which is one of the router’s addresses
https://wiki.mikrotik.com/wiki/Manual:IP/Firewall/Filter#Chains
is work. Thank you
You can mark the post as solved…
