How to block websites?
I looked thro google for tutorials how to block websites and found 2 ways on Firewall Filter Rules:
  1. using Layer 7 Protocols where you add website like this ^.+(facebook.com).*$
  2. adding TLS Host like this *.facebook.com
    None of these methods work, can someone please help me identify problem?
Could you post the output of the following command so we can figure out what is not working on your setup?
/ip firewall export
There you go.
Only I replaced facebook.com with draugiem.lv
/ip firewall export
# sep/15/2019 08:52:33 by RouterOS 6.45.6
# software id = BGH5-G73M
# model = RBD52G-5HacD2HnD
# serial number = B4A00AE025EA
/ip firewall layer7-protocol
add comment="Block Bit Torrent" name=layer7-bittorrent-exp regexp="^(\\x13bittorrent protocol|azver\\x01\$|get /scrape\\\?info_hash=get \
    /announce\\\?info_hash=|get /client/bitcomet/|GET /data\\\?fid=)|d1:ad2:id20:|\\x08'7P\\)[RP]"
add name=blocked regexp="^.+(draugiem.lv).*\$"
/ip firewall address-list
add address=0.0.0.0/8 comment=RFC6890 list=NotPublic
add address=10.0.0.0/8 comment=RFC6890 list=NotPublic
add address=100.64.0.0/10 comment=RFC6890 list=NotPublic
add address=127.0.0.0/8 comment=RFC6890 list=NotPublic
add address=169.254.0.0/16 comment=RFC6890 list=NotPublic
add address=172.16.0.0/12 comment=RFC6890 list=NotPublic
add address=192.0.0.0/24 comment=RFC6890 list=NotPublic
add address=192.0.2.0/24 comment=RFC6890 list=NotPublic
add address=192.168.0.0/16 comment=RFC6890 list=NotPublic
add address=192.88.99.0/24 comment=RFC3068 list=NotPublic
add address=198.18.0.0/15 comment=RFC6890 list=NotPublic
add address=198.51.100.0/24 comment=RFC6890 list=NotPublic
add address=203.0.113.0/24 comment=RFC6890 list=NotPublic
add address=224.0.0.0/4 comment=RFC4601 list=NotPublic
add address=240.0.0.0/4 comment=RFC6890 list=NotPublic
add action=accept chain=input comment="Accept ICMP (ping)" protocol=icmp
add action=accept chain=input comment="Accept established, related" connection-state=established,related
add action=accept chain=input comment="Allow everything from Main Router" src-address=192.168.40.0/24
add action=drop chain=input comment="Drop all packets which does not have unicast source IP address" src-address-type=!unicast
add action=drop chain=input comment="Drop all packets which are not destined to routes IP address" dst-address-type=!local
add action=drop chain=input comment="Drop invalid connections" connection-state=invalid
add action=drop chain=input comment="drop ssh brute forcers" dst-port=22 protocol=tcp src-address-list=ssh_blacklist
add action=drop chain=input comment="drop ftp brute forcers" disabled=yes dst-port=21 protocol=tcp src-address-list=ftp_blacklist
add action=add-src-to-address-list address-list=ssh_blacklist address-list-timeout=1w3d chain=input comment="SSH Stage 3" \
    connection-state=new dst-port=22 protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 address-list-timeout=1m chain=input comment="SSH Stage 2" connection-state=\
    new dst-port=22 protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 address-list-timeout=1m chain=input comment="SSH Stage 1" connection-state=\
    new dst-port=22 protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 address-list-timeout=1m chain=input comment="SSH Stage 1" connection-state=\
add action=accept chain=output comment="Burst 9" content="530 Login incorrect" disabled=yes dst-limit=1/1m,9,dst-address/1m protocol=\
    tcp
add action=add-dst-to-address-list address-list=ftp_blacklist address-list-timeout=3h chain=output comment="FTP brute" content=\
    "530 Login incorrect" disabled=yes protocol=tcp
add action=accept chain=forward comment="Allow established, related connections" connection-state=established,related
add action=accept chain=forward comment="Accept ICMP (ping)" protocol=icmp
add action=accept chain=forward comment="Allow everything from Main Router" src-address=192.168.40.0/24
add action=accept chain=forward comment="Allow connect to outside internet" in-interface=bridge
add action=drop chain=forward comment="Block website TLS Host" dst-port=80,443 protocol=tcp tls-host=*draugiem.lv
add action=drop chain=forward comment="Block website Layer 7" layer7-protocol=blocked
add action=drop chain=forward comment="Drop invalid" connection-state=invalid
add action=drop chain=forward comment="Drop all packets from public internet which should not exist in public network" in-interface=\
    ether1 src-address-list=NotPublic
add action=drop chain=forward comment="Drop all packets from local network to internet which should not exist in public network" \
    dst-address-list=NotPublic in-interface=bridge
add action=drop chain=forward comment="drop all from WAN not DSTNATed " connection-nat-state=!dstnat connection-state=new in-interface=\
    ether1
You have to move the tls-host and layer-7 rules before accepting related/established connections.
Indeed, someone saves the day, thanks.
I try many filter rules, but i can't block any website, can you help me, what do i wrong?
This is my firewall rules.: I want block facebook, and youtube, and porn site.
nov/10/2019 17:17:26 by RouterOS 6.45.7
software id = SHCP-ZT2V
model = 2011L
serial number = 3D6D02428491
*add action=drop chain=forward dst-port=80,443 protocol=tcp tls-host=
facebook.com
"defconf: accept established,related,untracked" connection-state=
add action=accept chain=input comment=WINBOX dst-port=8291 protocol=tcp
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=drop chain=input comment="defconf: drop all not coming from LAN"
in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
"defconf: accept established,related, untracked" connection-state=
add action=drop chain=forward comment="defconf: drop invalid" connection-state=
invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
connection-state=new in-interface="ether1 DIGI NET"
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=
out,none out-interface-list=all
add action=dst-nat chain=dstnat dst-port=8096 protocol=tcp src-port=""
to-addresses=192.168.88.42 to-ports=8096
add action=dst-nat chain=dstnat dst-port=55266 protocol=tcp src-port=""
to-addresses=192.168.88.42 to-ports=55266
