how to block Windows Live Messenger
soory for this old question as i think its repeat it self every time
i need to block all the chat in the university starting with the msn i tried all kind of stuf that writting in google (from ports ,urll …)nothing works i found student go around .is there a way to block that even if its necasary to block hotmail. if there is away pls advise
thanks in advance
There is no any universal solution, when you block one port and MSN stops working. You can look in Google for the ways people are trying to block MSN. As MSN can use 80 port and bunch of other ports.
http://www.plevna.f9.co.uk/messengers/blockwindowslivemessenger.htm
here u have something for that but i mean that u can block from the regedit too
hope that i help
thanks i allready used this but the thing is we have more than 200 pcs since this is the only solution i install it 200 times hhhhhhhhhhh.
I’m assuming the 200 PCs are part of windows domain? If so you can use the domain controller to set group policies and disable messenger system wide.
http://support.microsoft.com/kb/302089
