how to bond dual nstreme.
well can anyone tell me how to bond dual nstream…
plzz explian it very deeply.
Are you talking about bonding two dual nstreme links?
Dual nstreme by itself doesn’t require any bonding.. it just uses one radio for transmit and the other for receive to achieve a full duplex link.
Now if you wanted to achieve twice the throughput of a standard dual nstreme link you’d need to bond the two dual nstreme links..
So what are you trying to do?
thx wildbill…
yes u are right i need to double the throughput…how to do that?
shd i make two dual nstream and then bond it..oppps i m very much confused…actullally i need good throughput..which can afford about 150 users where each cleint is having a connection of 128 kbps or higher…(or will dual nstream is itself sufficent) to afford 150 internet users..assuming that 100 users will be online all the time..
thxx n regard…
