How to bonding multiple 3G modem with mikrotik
I’ve recently purchased a Mikrotik RB751G, I need help to configured to bonding multiple 3G modems with 3 parts or 4 parts of 3G USB modems connected to USB hub. the same like the picture below.
Many Thanks
Do like this http://www.wirelessinfo.be/index.php/mikrotik/pages/3g
Every modem must be natted and masqurade appart
Thank you so much for this info I get some idea from it, put please guide me to configured by video if passible for three 3G USB modem please.
Many Thanks
First of all, just a Control question.
Are you doing this because you think you will be able to combine all the modems into a “single pipe” with better speed? If so: This simply is not possible without support from the operator.
If you have 8+8+8Mbps (or whatever) you will NOT be able to download with 24Mbps. You will be able to (with careful routing) download Three separate things with 8Mbps.
I figured that i was best to get that out of the way first.
What you want to do is not easy. You will problably not find a 1-2-3 video that shows this.
Dear all
I found this idea from this forum below but it give confused for the scripting the modem so I just I need more info and view about this idea.
http://mybroadband.co.za/vb/showthread.php/400897-MikroTik-RouterBoard-and-USB-3G-Modems
i know this is an old post but i am really wondering how is this achieved by http://teradek.com/pages/bonding-solutions where they are bonding difference USB Data Streams
There is no miracle. It is described there. They use sputnik server to join all streams together.
