how to Bridge 2 mikrotik device (sxt , 433ah )
hi
in sxt, ether1 and wlan1 is bridged. and bridge has 192.168.1.53/24 ip.
in rb433 ether 3 has 192.168.1.52/24
my rb433 connected to sxt with ether 3
now the problem is that i can ping sxt from rb433 but cant ping other 192.168.1.x device that connected to wlan1(sxt)
note that sxt can ping them!
Dear ,
You can use bridge in two side from SXT and RB433 , or use EOIP link between us , this good idea for use EOIP for link …
This would be my suggestion:
http://wiki.mikrotik.com/wiki/Transparently_Bridge_two_Networks_using_MPLS
You can bridge the ap in ap bridge mode or bridge mode. You can not bridge the station without using station wds mode. Search the wiki fir transparent bridge. Mpls and EOIP tunnels are also options but a bit harder to set up.
hi.. i have same problem and i’m newbie total in wireless.
could i make bridge interface for wlan interface and ehternet interface in RB433 and SXT too? after that could i ping from network under ehter SXT interface to network under ehter RB433 interface?
please need your help.
vahid023, are there any IP or bridge firewall rules on SXT that could block this ping?
in sxt, check the wireless mode you are using, some of them can not be used when you add wlan as a port in bridge. your bridge seems not working correctly now.
