Hi there…I am new to MIKROTIK and i wanted to make a 5km link with 2 router boards. So i started to read the howto about bridge with WDS. And then realized that one of the router boards has license level 3 and the other level 4.
The one with level 3 is unable to use AP BRIDGE mode so i cant make the connection. Can anyone tell me a way of making this link without upgrading license…
(link parameters: 5km long
needs to provide 18mbits…it will be used by 80 users so i need it stable.a friend of myne told me that i need bridge mode
If you are just connecting two sites with one link you don’t need to use AP Bridge - you can just use bridge which is the same thing but only allows one connection.
Thanks for the help CarulloS. I did the connection before I read the post but thanks anyways i use bridge for AP and station for CLIENT. both boards are with EoIP interface and a Bridge between ether1 and EoIP.
Hope this conf. helps other people in situation like me
