how to bridge VLAN with Virtual AP ?
hi2all
help anyone with such problem please.
there is a one central Mikrotik with wlan1 and ether2. And 3 separate mikrotik with wlan1 and wlan2, which are connected to central with dynamic wds. other side of each mikrotik are 100 clients wich have network 10.0.0.0/16
how to isolate 3 wds links on main mikrotik?
i try to create 3 VAP and 3 VLAN and brigde them to each others. but it doesn’t work..
sorry for my poor english:( i hope you understand me.
in the centra mikrotik config is
[admin@MikroTik] > interface wireless print
 0  R name="wlan2" mtu=1500 mac-address=00:0C:42:26:C6:67 arp=enabled interface-type=Atheros AR5413 mode=ap-bridge
      ssid="hotellink" frequency=2422 band=2.4ghz-b/g scan-list=default antenna-mode=ant-a wds-mode=dynamic
      wds-default-bridge=bridge1 wds-ignore-ssid=no default-authentication=no default-forwarding=no
      default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default compression=no
[admin@MikroTik] > interface bridge print
 0  R name="bridge1" mtu=1500 arp=enabled mac-address=00:0C:42:26:C6:67 protocol-mode=none priority=0x8000 auto-mac=yes
      admin-mac=00:00:00:00:00:00 max-message-age=20s forward-delay=15s transmit-hold-count=6 ageing-time=5m
 1 X  name="vlan1_link1" mtu=1500 arp=enabled mac-address=00:00:00:00:00:00 protocol-mode=none priority=0x8000
      auto-mac=yes admin-mac=00:00:00:00:00:00 max-message-age=20s forward-delay=15s transmit-hold-count=6
      ageing-time=5m
[admin@MikroTik] > interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
 #    INTERFACE                                  BRIDGE                                  PRIORITY PATH-COST  HORIZON
 0    ether2                                     bridge1                                 0x80     10         none
 1    wlan2                                      bridge1                                 0x80     10         none
 4  D wds1                                       bridge1                                 0x80     95         none
 5  D wds2                                       bridge1                                 0x80     93         none
 6  D wds3                                       bridge1                                 0x80     94         none
[admin@MikroTik] > ip address print
 #   ADDRESS            NETWORK         BROADCAST       INTERFACE
 0   192.168.100.6/24   192.168.100.0   192.168.100.255 bridge1
and config of each other 3 mikrotiks are same
 0  R name="wlan1" mtu=1500 mac-address=00:0C:42:1F:22:EC arp=enabled interface-type=Atheros AR5413 mode=ap-bridge
      ssid="net100.7" frequency=2427 band=2.4ghz-b/g scan-list=default antenna-mode=ant-a wds-mode=disabled
      wds-default-bridge=none wds-ignore-ssid=no default-authentication=yes default-forwarding=no
 1  R name="wlan2" mtu=1500 mac-address=00:0C:42:1F:1A:E3 arp=enabled interface-type=Atheros AR5413 mode=station-wds
      wds-default-bridge=bridge1 wds-ignore-ssid=no default-authentication=yes default-forwarding=yes
 0  R name="bridge1" mtu=1500 arp=enabled mac-address=00:0C:42:1F:22:EC protocol-mode=none priority=0x8000 auto-mac=yes
 0    wlan2                                      bridge1                                 0x80     10         none
 1    wlan1                                      bridge1                                 0x80     10         none
 0   192.168.100.7/24   192.168.100.0   192.168.100.255 bridge1
