Hello.
I have 2 devices, the RB2011 RouterBOARD (with RJ45 serial port) and the US Robotics Data/Fax modem(with DB-25 pin serial port) …
How can I create a cable for connecting the Data/Fax modem to the RouterBOARD ?!
I want to send an AT command to the Data/Fax modem and receive result from the modem.
I don’t have any problem with the modem in the RouterOS(installed on x86 hardware) …
Thanks.
