How to build L2TP/IPSec server for multiple incoming connections with static interface/rules
I have set up an L2TP/IPSec VPN server according to the ‘road warrior’ setup in the Wiki: http://wiki.mikrotik.com/wiki/Manual:Interface/L2TP#L2TP.2FIpSec_setup
This works so far, but as the interface for each incoming connection is dynamically created, I cannot define firewall rules to filter or forward packets.
How do I define the same setup for multiple users and multiple connections at the same time but with a static interface as the endpoint?
Thanks!
Christophe
Use server binding as independent interface.
