How to Bypass Queue for internal file server
I put file server into my network for file sharing but I found the traffic from that server is go throw MT Queue . how I can make the server work with Lan speed.
This my net work look like
Rb 750 local1 192.168.0.1
local2 192.168.10.1
File server 192.168.0.254
Depends on how you’re queueing. Post the output of “/ip address print detail”, “/ip route print detail”, “/interface print”, “/ip firewall export”, “/queue export”, and an accurate network diagram
thanks fewi
thats my mt configer:
admin@MikroTik] /ip address> pr
ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.0.1/24 192.168.0.0 192.168.0.255 Local
1 100.100.100.50/24 100.100.100.0 100.100.100.255 WAN1
2 I 10.10.10.5/24 10.10.10.0 10.10.10.255 WAN2
3 192.168.10.1/24 192.168.10.0 192.168.10.255 local2
[admin@MikroTik] /ip route> pr
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 100.100.100.100 1
1 S 0.0.0.0/0 10.10.10.10 1
2 A S 0.0.0.0/0 100.100.100.100 1
3 S 0.0.0.0/0 10.10.10.10 2
4 ADC 100.100.100.0/24 100.100.100.50 WAN1 0
5 ADC 192.168.0.0/24 192.168.0.1 Local 0
6 ADC 192.168.10.0/24 192.168.10.1 local2 0
[admin@MikroTik] /interface> pr
NAME TYPE MTU L2MTU
0 R WAN1 ether 1500 1526
1 R local2 ether 1500 1524
2 X WAN2 ether 1500 1524
3 X cash ether 1500 1524
4 R Local ether 1500 1524
wrapped
jan/02/1970 03:20:47 by RouterOS 4.10
software id = 4Q1V-TDQ5
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514
sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000
red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=
5
set default-small kind=pfifo name=default-small pfifo-limit=10
/queue simple
add burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s comment=""
direction=both disabled=no dst-address=0.0.0.0/0 interface=Local
limit-at=0/0 max-limit=0/0 name="asmil dish" parent=none priority=8
queue=default/default target-addresses=192.168.0.2/32 total-queue=default
limit-at=0/0 max-limit=2M/20M name=3 parent=none priority=8 queue=
default/default target-addresses=192.168.0.3/32 total-queue=default
limit-at=0/0 max-limit=8M/1M name=9 parent=none priority=8 queue=
default/default target-addresses=192.168.0.9/32 total-queue=default
limit-at=0/0 max-limit=128k/256k name=11 parent=none priority=8 queue=
default/default target-addresses=192.168.0.11/32 total-queue=default
limit-at=0/0 max-limit=64k/256k name=12 parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.12/32 total-queue=
default-small
limit-at=0/0 max-limit=128k/256k name=13 parent=none priority=8 queue=
default/default target-addresses=192.168.0.13/32 total-queue=default
limit-at=0/0 max-limit=64k/256k name=14 parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.14/32 total-queue=
default-small
limit-at=0/0 max-limit=64k/256k name=15 parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.15/32 total-queue=
default-small
limit-at=0/0 max-limit=64k/64k name="a ramdan dish" parent=none priority=
8 queue=default-small/default-small target-addresses=192.168.0.16/32
total-queue=default-small
limit-at=0/0 max-limit=128k/2M name=17 parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.17/32 total-queue=
default-small
limit-at=0/0 max-limit=64k/256k name=saeed parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.20/32 total-queue=
default-small
limit-at=0/0 max-limit=64k/200k name="a ramdan" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.28/32
limit-at=0/0 max-limit=64k/200k name="a mostfa ***closed" parent=none
priority=8 queue=default-small/default-small target-addresses=
192.168.0.29/32 total-queue=default-small
limit-at=0/0 max-limit=64k/256k name=empty1 parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.30/32 total-queue=
default-small
limit-at=0/0 max-limit=64k/200k name="dr m ibrahim" parent=none priority=
8 queue=default-small/default-small target-addresses=192.168.0.31/32
limit-at=0/0 max-limit=64k/200k name="a m zaki" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.32/32
limit-at=0/0 max-limit=64k/128k name="ebrahum ali" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.33/32
limit-at=0/0 max-limit=64k/200k name="osama baumoi" parent=none priority=
8 queue=default-small/default-small target-addresses=192.168.0.34/32
limit-at=0/0 max-limit=64k/256k name="a ismil" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.35/32
limit-at=0/0 max-limit=64k/256k name="g abd alaziz" parent=none priority=
8 queue=default-small/default-small target-addresses=192.168.0.38/32
limit-at=0/0 max-limit=64k/168k name="ashrf albahy" parent=none priority=
8 queue=default-small/default-small target-addresses=192.168.0.39/32
limit-at=0/0 max-limit=64k/200k name="hassan nassar" parent=none
192.168.0.40/32 total-queue=default-small
limit-at=0/0 max-limit=64k/128k name="osama nsur abas" parent=none
192.168.0.41/32 total-queue=default-small
limit-at=0/0 max-limit=64k/200k name="amad awad" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.42/32
limit-at=0/0 max-limit=64k/256k name="a hesham bauomy" parent=none
192.168.0.43/32 total-queue=default-small
limit-at=0/0 max-limit=64k/256k name="a abd alaziz" parent=none priority=
8 queue=default-small/default-small target-addresses=192.168.0.44/32
limit-at=0/0 max-limit=64k/256k name="saleh kobury" parent=none priority=
8 queue=default-small/default-small target-addresses=192.168.0.46/32
limit-at=0/0 max-limit=64k/200k name="karum maged" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.47/32
direction=both disabled=no dst-address=0.0.0.0/0 interface=all limit-at=
0/0 max-limit=64k/200k name=bola parent=none priority=8 queue=
default/default target-addresses=192.168.0.48/32 total-queue=default
limit-at=0/0 max-limit=64k/200k name="m abd elmoaam" parent=none
192.168.0.49/32 total-queue=default-small
limit-at=0/0 max-limit=128k/512k name="a slem" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.50/32
limit-at=0/0 max-limit=64k/256k name="hag blbol" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.52/32
limit-at=0/0 max-limit=64k/200k name=elshtry parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.54/32
0/0 max-limit=64k/200k name="m eldeeb" parent=none priority=8 queue=
default/default target-addresses=192.168.0.55/32 total-queue=default
0/0 max-limit=64k/256k name=dezel parent=none priority=8 queue=
default/default target-addresses=192.168.0.56/32 total-queue=default
limit-at=0/0 max-limit=64k/400k name="ramy elazhry" parent=none priority=
192.168.0.57/32,192.168.0.157/32 total-queue=default-small
limit-at=0/0 max-limit=64k/200k name="a gamal" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.58/32
limit-at=0/0 max-limit=64k/200k name=remon parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.59/32 total-queue=
default-small
limit-at=0/0 max-limit=64k/200k name=gorg parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.60/32 total-queue=
default-small
limit-at=0/0 max-limit=64k/256k name="yaser abd wahed" parent=none
192.168.0.61/32 total-queue=default-small
limit-at=0/0 max-limit=32/32 name=empty2 parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.62/32 total-queue=
default-small
limit-at=0/0 max-limit=64k/256k name="fathe m atua" parent=none priority=
8 queue=default-small/default-small target-addresses=192.168.0.63/32
limit-at=0/0 max-limit=64/12 name="yasmun ahmed" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.64/32
limit-at=0/0 max-limit=64k/200k name="m slem" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.65/32
limit-at=0/0 max-limit=64k/200k name="hosam gamal" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.66/32
limit-at=0/0 max-limit=64k/256k name=nasar2 parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.67/32 total-queue=
default-small
limit-at=0/0 max-limit=64k/200k name="mah sameh" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.69/32
limit-at=0/0 max-limit=64k/64k name="a kaled" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.70/32
limit-at=0/0 max-limit=128k/256k name="dr ebthag" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.71/32
limit-at=0/0 max-limit=64k/200k name="mazen omar" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.73/32
limit-at=0/0 max-limit=64k/256k name="mohsen faumouy" parent=none
192.168.0.74/32 total-queue=default-small
limit-at=0/0 max-limit=96k/128k name="m abdo" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.75/32
limit-at=0/0 max-limit=64k/200k name="m farg" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.77/32
limit-at=0/0 max-limit=64k/168k name="a erlsyed-m aysa" parent=none
192.168.0.79/32 total-queue=default-small
limit-at=0/0 max-limit=64k/64k name=empty3 parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.80/32 total-queue=
default-small
limit-at=0/0 max-limit=64k/256k name="abd menam saber 1" parent=none
192.168.0.91/32 total-queue=default-small
limit-at=0/0 max-limit=64k/256k name="a mah dosoky" parent=none priority=
8 queue=default-small/default-small target-addresses=192.168.0.82/32
limit-at=0/0 max-limit=64k/256k name="abd manuam saber2" parent=none
192.168.0.83/32 total-queue=default-small
limit-at=0/0 max-limit=64k/128k name="ramy katab st." parent=none
192.168.0.84/32 total-queue=default-small
limit-at=0/0 max-limit=64k/256k name=annas parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.86/32 total-queue=
default-small
limit-at=0/0 max-limit=64k/256k name=luathy parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.87/32 total-queue=
default-small
limit-at=0/0 max-limit=64k/256k name="m abd maneem" parent=none priority=
8 queue=default-small/default-small target-addresses=192.168.0.89/32
limit-at=0/0 max-limit=64k/128k name="a abd hamed" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.90/32
limit-at=0/0 max-limit=64k/200k name="mah goda" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.91/32
limit-at=0/0 max-limit=64k/200k name=pola2 parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.92/32 total-queue=
default-small
limit-at=0/0 max-limit=64k/200k name="abo shady" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.94/32
limit-at=0/0 max-limit=64k/256k name="m aysa" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.98/32
direction=both disabled=no dst-address=0.0.0.0/0 interface=local2
limit-at=0/0 max-limit=64k/128k name="dr mohamed" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.7/32
limit-at=0/0 max-limit=2M/1M name=home parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.10.9/32 total-queue=
default-small
limit-at=0/0 max-limit=64/200 name="mah buomy mob" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.10/32
limit-at=0/0 max-limit=64k/200k name="zezo mob" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.11/32
limit-at=0/0 max-limit=64k/128k name="nokia mob" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.13/32
limit-at=0/0 max-limit=64k/200k name="m osama" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.14/32
limit-at=0/0 max-limit=64k/400k name="eslam zakria" parent=none priority=
8 queue=default-small/default-small target-addresses=192.168.10.15/32
limit-at=0/0 max-limit=64k/256k name="a hesham bauomy2" parent=none
192.168.10.16/32 total-queue=default-small
limit-at=0/0 max-limit=64k/256k name="osama elmahdy" parent=none
192.168.10.17/32 total-queue=default-small
limit-at=0/0 max-limit=128k/168k name="kaled albokary" parent=none
192.168.10.18/32 total-queue=default-small
limit-at=0/0 max-limit=64k/200k name="osama elmahdy2" parent=none
192.168.10.19/32 total-queue=default-small
limit-at=0/0 max-limit=64k/128k name="nasar lab" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.20/32
limit-at=0/0 max-limit=64k/256k name=atef parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.10.21/32
limit-at=0/0 max-limit=64k/200k name=samera parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.10.22/32
limit-at=0/0 max-limit=64k/200k name="hamda mss sana" parent=none
192.168.0.24/32 total-queue=default-small
limit-at=0/0 max-limit=64k/128k name="mobil shop" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.25/32
limit-at=0/0 max-limit=128k/200k name=ehab parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.10.26/32
limit-at=0/0 max-limit=64k/128k name="a elashrm" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.27/32
limit-at=0/0 max-limit=64k/128k name="m salh dish" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.28/32
limit-at=0/0 max-limit=64k/128k name="mah elmslmy" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.31/32
limit-at=0/0 max-limit=64k/128k name="aymen moh ali" parent=none
192.168.10.34/32 total-queue=default-small
limit-at=0/0 max-limit=64k/200k name="alaa saber" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.36/32
limit-at=0/0 max-limit=64k/200k name="noor $ mohamed" parent=none
192.168.10.37/32 total-queue=default-small
limit-at=0/0 max-limit=64k/200k name=hamada parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.10.45/32
limit-at=0/0 max-limit=64k/200k name="karum kaled" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.39/32
limit-at=0/0 max-limit=64k/128k name="taerk ismail" parent=none priority=
8 queue=default-small/default-small target-addresses=192.168.10.41/32
limit-at=0/0 max-limit=64k/128k name="eslam hefny" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.43/32
limit-at=0/0 max-limit=64k/256k name="a mohamdy" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.44/32
limit-at=0/0 max-limit=64k/128k name="hamad dish" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.46/32
limit-at=0/0 max-limit=64k/168k name="mah tark" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.50/32
limit-at=0/0 max-limit=64k/128k name="a abd nasr fathy" parent=none
192.168.10.61/32 total-queue=default-small
limit-at=0/0 max-limit=64k/200k name="aymen maarof" parent=none priority=
8 queue=default-small/default-small target-addresses=192.168.10.65/32
limit-at=0/0 max-limit=64k/256k name="elsyd ibrahum kaml" parent=none
192.168.10.66/32 total-queue=default-small
limit-at=0/0 max-limit=64k/256k name="m hasan a" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.69/32
limit-at=0/0 max-limit=64k/256k name="mah gaber" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.71/32
limit-at=0/0 max-limit=64k/200k name="m salh pc" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.79/32
limit-at=0/0 max-limit=64k/256k name="osama bauomy lab" parent=none
192.168.10.90/32 total-queue=default-small
limit-at=0/0 max-limit=64k/400k name="a abd alaziz local2" parent=none
192.168.10.91/32 total-queue=default-small
limit-at=0/0 max-limit=64k/256k name="hesham saaed" parent=none priority=
8 queue=default-small/default-small target-addresses=192.168.10.92/32
limit-at=0/0 max-limit=64k/400k name="a abd aziz -cabl" parent=none
192.168.10.93/32 total-queue=default-small
limit-at=0/0 max-limit=64k/256k name="maha ashry" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.94/32
limit-at=0/0 max-limit=128k/512k name="elmostfa lab local2" parent=none
192.168.10.101/32 total-queue=default-small
limit-at=0/0 max-limit=128k/512k name="elmostfa lab cable" parent=none
192.168.0.103/32 total-queue=default-small
limit-at=0/0 max-limit=64k/128k name="mr abd fatha" parent=none priority=
8 queue=default-small/default-small target-addresses=192.168.10.110/32
limit-at=0/0 max-limit=64k/200k name="mr abd fath 2" parent=none
192.168.10.111/32 total-queue=default-small
limit-at=0/0 max-limit=64k/256k name="m atua" parent=none priority=8
queue=default/default target-addresses=192.168.10.130/32 total-queue=
default
limit-at=0/0 max-limit=64k/128k name="m atua dish" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.131/32
limit-at=0/0 max-limit=64k/168k name="adel hefnawy" parent=none priority=
8 queue=default-small/default-small target-addresses=192.168.10.155/32
limit-at=0/0 max-limit=64k/256k name="adel alsyed" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.171/32
limit-at=0/0 max-limit=128k/256k name=elazony parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.182/32
limit-at=0/0 max-limit=64k/200k name="aymen ali" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.184/32
limit-at=0/0 max-limit=64k/200k name=hanon parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.10.185/32
limit-at=0/0 max-limit=64k/200k name=noha parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.10.186/32
limit-at=0/0 max-limit=64k/128k name="moh adnan" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.188/32
limit-at=0/0 max-limit=64k/256k name="hesh 2" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.192/32
limit-at=0/0 max-limit=64k/256k name="aymen sister lab" parent=none
192.168.10.199/32 total-queue=default-small
limit-at=0/0 max-limit=64k/256k name=elgohry parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.201/32
limit-at=0/0 max-limit=128k/512k name="algohry 2" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.202/32
limit-at=0/0 max-limit=64k/256k name="elgohry lab" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.205/32
limit-at=0/0 max-limit=64k/168k name="m elawdy" parent=none priority=8
192.168.10.230/32,192.168.10.231/32 total-queue=default-small
limit-at=0/0 max-limit=64k/256k name="dr abd rhman fuomy" parent=none
192.168.10.235/32 total-queue=default-small
limit-at=0/0 max-limit=64k/256k name="elshefa lab" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.236/32
limit-at=0/0 max-limit=64k/256k name="dr awad besar" parent=none
192.168.10.237/32 total-queue=default-small
limit-at=0/0 max-limit=64k/200k name="dr moh2" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.122/32
limit-at=0/0 max-limit=64k/168k name=sameh-mena parent=none priority=8
queue=default/default target-addresses=192.168.0.161/32 total-queue=
default
limit-at=0/0 max-limit=64k/256k name=mena parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.162/32
limit-at=0/0 max-limit=128k/200k name=hasan parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.163/32
limit-at=0/0 max-limit=128k/256k name=mounur parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.164/32 time=
0s-0s, total-queue=default-small
limit-at=0/0 max-limit=128k/200k name="mah sameh2" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.169/32
limit-at=0/0 max-limit=64k/200k name="m dsoky lab" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.182/32
limit-at=0/0 max-limit=64k/256k name=omar parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.190/32
limit-at=0/0 max-limit=128k/512k name="elmostfa lap cable" parent=none
priority=8 queue=default/default target-addresses=192.168.10.103/32
total-queue=default
limit-at=0/0 max-limit=64k/256k name=aklas parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.51/32 total-queue=
default-small
limit-at=0/0 max-limit=64k/256k name=zezo parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.10.72/32
limit-at=0/0 max-limit=64k/256k name=10.35 parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.10.40/32
limit-at=0/0 max-limit=64k/256k name="wael bekuut" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.10.197/32
limit-at=0/0 max-limit=64k/200k name="abd man3m arfa" parent=none
192.168.0.81/32 total-queue=default-small
limit-at=0/0 max-limit=64k/256k name=10-8 parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.10.8/32 total-queue=
default-small
limit-at=0/0 max-limit=64k/128k name=19 parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.19/32 total-queue=
default-small
limit-at=0/0 max-limit=64k/168k name="om yosef" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.76/32
limit-at=0/0 max-limit=64k/256k name="ahmed magdy" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.123/32
limit-at=0/0 max-limit=64k/256k name=172 parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.10.104/32
limit-at=0/0 max-limit=64k/200k name="shady essam" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.88/32
limit-at=0/0 max-limit=64k/256k name=maher parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.10.211/32
limit-at=0/0 max-limit=64k/256k name="hag blbol 2" parent=none priority=8
queue=default-small/default-small target-addresses=192.168.0.78/32
0/0 max-limit=64k/400k name=m.hafez parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.10.238/32
0/0 max-limit=64k/256k name="dr ahmed" parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.21/32 total-queue=
default-small
limit-at=0/0 max-limit=64k/256k name=10-64 parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.10.57/32
limit-at=0/0 max-limit=128k/256k name="POLA NET PHONE" parent=none
192.168.0.18/32 total-queue=default-small
limit-at=0/0 max-limit=64k/128k name=10-12 parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.10.24/32
limit-at=0/0 max-limit=64k/200k name=10-3 parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.10.3/32 total-queue=
default-small
limit-at=0/0 max-limit=64k/200k name=10-4 parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.10.5/32 total-queue=
default-small
limit-at=0/0 max-limit=64k/256k name=nasar parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.53/32 total-queue=
default-small
limit-at=0/0 max-limit=64k/256k name=0.5 parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.6/32 total-queue=
default-small
limit-at=0/0 max-limit=64k/128k name=0.93 parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.93/32 total-queue=
default-small
0/0 max-limit=64k/256k name=0.57 parent=none priority=8 queue=
default-small/default-small target-addresses=192.168.0.157/32
/queue interface
set WAN1 queue=ethernet-default
set local2 queue=ethernet-default
set WAN2 queue=ethernet-default
set cash queue=ethernet-default
set Local queue=ethernet-default
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment=
"place hotspot rules here" disabled=yes
add action=drop chain=virus comment="Drop Blaster Worm" disabled=no dst-port=
135-139 protocol=tcp
add action=drop chain=virus comment="Drop Messenger Worm" disabled=no
dst-port=135-139 protocol=udp
445 protocol=tcp
445 protocol=udp
add action=drop chain=virus comment=________ disabled=no dst-port=593
protocol=tcp
add action=drop chain=virus comment=________ disabled=no dst-port=1024-1030
protocol=tcp
add action=drop chain=virus comment="Drop MyDoom" disabled=no dst-port=1080
protocol=tcp
add action=drop chain=virus comment=________ disabled=no dst-port=1214
protocol=tcp
add action=drop chain=virus comment="ndm requester" disabled=no dst-port=1363
protocol=tcp
add action=drop chain=virus comment="ndm server" disabled=no dst-port=1364
protocol=tcp
add action=drop chain=virus comment="screen cast" disabled=no dst-port=1368
protocol=tcp
add action=drop chain=virus comment=hromgrafx disabled=no dst-port=1373
protocol=tcp
add action=drop chain=virus comment=cichlid disabled=no dst-port=1377
protocol=tcp
add action=drop chain=virus comment=Worm disabled=no dst-port=1433-1434
protocol=tcp
add action=drop chain=virus comment="Bagle Virus" disabled=no dst-port=2745
protocol=tcp
add action=drop chain=virus comment="Drop Dumaru.Y" disabled=no dst-port=2283
protocol=tcp
add action=drop chain=virus comment="Drop Beagle" disabled=no dst-port=2535
protocol=tcp
add action=drop chain=virus comment="Drop Beagle.C-K" disabled=no dst-port=
2745 protocol=tcp
3127-3128 protocol=tcp
add action=drop chain=virus comment="Drop Backdoor OptixPro" disabled=no
dst-port=3410 protocol=tcp
add action=drop chain=virus comment=Worm disabled=no dst-port=4444 protocol=
tcp
udp
add action=drop chain=virus comment="Drop Sasser" disabled=no dst-port=5554
protocol=tcp
add action=drop chain=virus comment="Drop Beagle.B" disabled=no dst-port=8866
protocol=tcp
add action=drop chain=virus comment="Drop Dabber.A-B" disabled=no dst-port=
9898 protocol=tcp
10000 protocol=tcp
add action=drop chain=virus comment="Drop MyDoom.B" disabled=no dst-port=
10080 protocol=tcp
add action=drop chain=virus comment="Drop NetBus" disabled=no dst-port=12345
protocol=tcp
add action=drop chain=virus comment="Drop Kuang2" disabled=no dst-port=17300
protocol=tcp
add action=drop chain=virus comment="Drop SubSeven" disabled=no dst-port=
27374 protocol=tcp
add action=drop chain=virus comment="Drop PhatBot, Agobot, Gaobot" disabled=
no dst-port=65506 protocol=tcp
add action=jump chain=forward comment="jump to the virus chain" disabled=no
jump-target=virus
add action=add-src-to-address-list address-list="port scanners"
address-list-timeout=2w chain=input comment="Port scanners to list "
disabled=no protocol=tcp psd=21,3s,3,1
address-list-timeout=2w chain=input comment="NMAP FIN Stealth scan
\n" disabled=no protocol=tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg
address-list-timeout=2w chain=input comment="" disabled=no protocol=tcp
tcp-flags=fin,syn
address-list-timeout=2w chain=input comment="SYN/FIN scan" disabled=no
protocol=tcp tcp-flags=fin,syn
address-list-timeout=2w chain=input comment="SYN/RST scan" disabled=no
protocol=tcp tcp-flags=syn,rst
address-list-timeout=2w chain=input comment="FIN/PSH/URG scan" disabled=
no protocol=tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack
address-list-timeout=2w chain=input comment="ALL/ALL scan" disabled=no
protocol=tcp tcp-flags=fin,syn,rst,psh,ack,urg
address-list-timeout=2w chain=input comment="NMAP NULL scan" disabled=no
protocol=tcp tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg
add action=drop chain=input comment="dropping port scanners" disabled=yes
src-address-list="port scanners"
address-list-timeout=2w chain=forward comment="Port scanners to list "
disabled=yes protocol=tcp psd=21,3s,3,1
address-list-timeout=2w chain=forward comment="NMAP FIN Stealth scan
address-list-timeout=2w chain=forward comment="" disabled=no protocol=tcp
tcp-flags=fin,syn
address-list-timeout=2w chain=forward comment="SYN/FIN scan" disabled=no
address-list-timeout=2w chain=forward comment="SYN/RST scan" disabled=no
address-list-timeout=2w chain=forward comment="FIN/PSH/URG scan"
disabled=no protocol=tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack
address-list-timeout=2w chain=forward comment="ALL/ALL scan" disabled=no
address-list-timeout=2w chain=forward comment="NMAP NULL scan" disabled=
no protocol=tcp tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg
add action=drop chain=forward comment="dropping port scanners" disabled=no
add action=jump chain=forward comment="" disabled=no jump-target=restrict-tcp
protocol=tcp
add action=jump chain=forward comment="" disabled=no jump-target=restrict-udp
protocol=udp
add action=jump chain=forward comment="" disabled=no jump-target=restrict-ip
add action=reject chain=restrict-tcp comment="" connection-mark=auth
disabled=no reject-with=icmp-network-unreachable
add action=jump chain=restrict-tcp comment="anti-spam policy"
connection-mark=smtp disabled=no jump-target=smtp-first-drop
add action=add-src-to-address-list address-list=approved-smtp
address-list-timeout=5s chain=smtp-first-drop comment="" disabled=no
src-address-list=first-smtp
add action=return chain=smtp-first-drop comment="" disabled=no
src-address-list=approved-smtp
add action=add-src-to-address-list address-list=first-smtp
add action=reject chain=smtp-first-drop comment="" disabled=no reject-with=
add action=jump chain=restrict-tcp comment="" connection-mark=other-tcp
disabled=no jump-target=drop
add action=jump chain=restrict-udp comment="" connection-mark=other-udp
add action=jump chain=restrict-ip comment="" connection-mark=other disabled=
no jump-target=drop
add action=accept chain=forward comment="allow established connections"
connection-state=established disabled=no
add action=accept chain=forward comment="allow related connections"
connection-state=related disabled=no
add action=drop chain=forward comment="drop invalid connections"
connection-state=invalid disabled=no
add action=accept chain=ICMP comment=Ping5 disabled=no icmp-options=0:0-255
limit=5,5 protocol=icmp
add action=accept chain=ICMP comment=Traceroute5 disabled=no icmp-options=3:3
add action=accept chain=ICMP comment=MTU5 disabled=no icmp-options=3:4 limit=
5,5 protocol=icmp
add action=accept chain=ICMP comment=Ping5 disabled=no icmp-options=8:0-255
add action=accept chain=ICMP comment="Trace TTL5" disabled=no icmp-options=
11:0-255 limit=5,5 protocol=icmp
add action=drop chain=ICMP comment=ICMP disabled=no protocol=icmp
add action=drop chain=forward comment="" connection-state=invalid disabled=no
add action=drop chain=forward comment="" disabled=no src-address-type=
!unicast
add action=jump chain=forward comment=ICMP disabled=no jump-target=ICMP
protocol=icmp
add action=jump chain=forward comment="" disabled=no jump-target=virus
add action=drop chain=virus comment=DeepThroat.Trojan-1 disabled=no dst-port=
41 protocol=tcp
add action=drop chain=virus comment=Worm.NetSky.Y@mm disabled=no dst-port=82
protocol=tcp
add action=drop chain=virus comment=W32.Korgo.A/B/C/D/E/F-1 disabled=no
dst-port=113 protocol=tcp
add action=drop chain=virus comment=W33.Korgo.A/B/C/D/E/F-2 disabled=no
dst-port=2041 protocol=tcp
add action=drop chain=virus comment=DeepThroat.Trojan-2 disabled=no dst-port=
3150 protocol=tcp
add action=drop chain=virus comment=W32.Korgo.A/B/C/D/E/F-3 disabled=no
dst-port=3067 protocol=tcp
add action=drop chain=virus comment=Backdoor.IRC.Aladdinz.R-1 disabled=no
dst-port=3422 protocol=tcp
add action=drop chain=virus comment=W32.Korgo.A/B/C/D/E/F-4 disabled=no
dst-port=6667 protocol=tcp
add action=drop chain=virus comment=Worm.NetSky.S/T/U@mm disabled=no
dst-port=6789 protocol=tcp
add action=drop chain=virus comment=Back.Orifice.2000.Trojan-1 disabled=no
dst-port=8787 protocol=tcp
add action=drop chain=virus comment=Back.Orifice.2000.Trojan-2 disabled=no
dst-port=8879 protocol=tcp
add action=drop chain=virus comment=W32.Dabber.A/B-2 disabled=no dst-port=
8967 protocol=tcp
add action=drop chain=virus comment=W32.Dabber.A/B-3 disabled=no dst-port=
9999 protocol=tcp
add action=drop chain=virus comment=Block.NetBus.Trojan-2 disabled=no
dst-port=20034 protocol=tcp
add action=drop chain=virus comment=GirlFriend.Trojan-1 disabled=no dst-port=
21554 protocol=tcp
add action=drop chain=virus comment=Back.Orifice.2000.Trojan-3 disabled=no
dst-port=31666 protocol=tcp
add action=drop chain=virus comment=Backdoor.IRC.Aladdinz.R-2 disabled=no
dst-port=43958 protocol=tcp
add action=drop chain=virus comment=DeepThroat.Trojan-3 disabled=no dst-port=
999 protocol=tcp
add action=drop chain=virus comment=DeepThroat.Trojan-4 disabled=no dst-port=
6670 protocol=tcp
add action=drop chain=virus comment=DeepThroat.Trojan-5 disabled=no dst-port=
6771 protocol=tcp
add action=drop chain=virus comment=DeepThroat.Trojan-6 disabled=no dst-port=
60000 protocol=tcp
add action=drop chain=virus comment=DeepThroat.Trojan-7 disabled=no dst-port=
2140 protocol=tcp
add action=drop chain=virus comment=Portal.of.Doom.Trojan-1 disabled=no
dst-port=10067 protocol=tcp
add action=drop chain=virus comment=Portal.of.Doom.Trojan-2 disabled=no
dst-port=10167 protocol=tcp
add action=drop chain=virus comment=Portal.of.Doom.Trojan-3 disabled=no
dst-port=3700 protocol=tcp
add action=drop chain=virus comment=Portal.of.Doom.Trojan-4 disabled=no
dst-port=9872-9875 protocol=tcp
add action=drop chain=virus comment=Delta.Source.Trojan-1 disabled=no
dst-port=6883 protocol=tcp
add action=drop chain=virus comment=Delta.Source.Trojan-2 disabled=no
dst-port=26274 protocol=tcp
add action=drop chain=virus comment=Delta.Source.Trojan-3 disabled=no
dst-port=4444 protocol=tcp
add action=drop chain=virus comment=Delta.Source.Trojan-4 disabled=no
dst-port=47262 protocol=tcp
add action=drop chain=virus comment=Eclypse.Trojan-1 disabled=no dst-port=
3791 protocol=tcp
add action=drop chain=virus comment=Eclypse.Trojan-2 disabled=no dst-port=
3801 protocol=tcp
add action=drop chain=virus comment=Eclypse.Trojan-3 disabled=no dst-port=
65390 protocol=tcp
add action=drop chain=virus comment=Y3K.RAT.Trojan-1 disabled=no dst-port=
5880-5882 protocol=tcp
add action=drop chain=virus comment=Y3K.RAT.Trojan-2 disabled=no dst-port=
5888-5889 protocol=tcp
add action=drop chain=virus comment=NetSphere.Trojan-1 disabled=no dst-port=
30100-30103 protocol=tcp
add action=drop chain=virus comment=NetSphere.Trojan-2 disabled=no dst-port=
30133 protocol=tcp
add action=drop chain=virus comment=NetMonitor.Trojan-1 disabled=no dst-port=
7300-7301 protocol=tcp
add action=drop chain=virus comment=NetMonitor.Trojan-2 disabled=no dst-port=
7306-7308 protocol=tcp
add action=drop chain=virus comment=FireHotcker.Trojan-1 disabled=no
dst-port=79 protocol=tcp
add action=drop chain=virus comment=FireHotcker.Trojan-2 disabled=no
dst-port=5031 protocol=tcp
add action=drop chain=virus comment=FireHotcker.Trojan-3 disabled=no
dst-port=5321 protocol=tcp
add action=drop chain=virus comment=TheThing.Trojan-1 disabled=no dst-port=
6400 protocol=tcp
add action=drop chain=virus comment=TheThing.Trojan-2 disabled=no dst-port=
7777 protocol=tcp
add action=drop chain=virus comment=GateCrasher.Trojan-1 disabled=no
dst-port=1047 protocol=tcp
add action=drop chain=virus comment=GateCrasher.Trojan-2 disabled=no
dst-port=6969-6970 protocol=tcp
add action=drop chain=virus comment=SubSeven-1 disabled=no dst-port=2774
protocol=tcp
add action=drop chain=virus comment=SubSeven-2 disabled=no dst-port=27374
protocol=tcp
add action=drop chain=virus comment=SubSeven-3 disabled=no dst-port=1243
protocol=tcp
add action=drop chain=virus comment=SubSeven-4 disabled=no dst-port=1234
protocol=tcp
add action=drop chain=virus comment=SubSeven-5 disabled=no dst-port=6711-6713
protocol=tcp
add action=drop chain=virus comment=SubSeven-7 disabled=no dst-port=16959
protocol=tcp
add action=drop chain=virus comment=Moonpie.Trojan-1 disabled=no dst-port=
25685-25686 protocol=tcp
add action=drop chain=virus comment=Moonpie.Trojan-2 disabled=no dst-port=
25982 protocol=tcp
add action=drop chain=virus comment=NetSpy.Trojan-3 disabled=no dst-port=
31337-31339 protocol=tcp
add action=drop chain=virus comment=Trojan disabled=no dst-port=8102
protocol=tcp
add action=drop chain=virus comment=WAY.Trojan disabled=no dst-port=8011
protocol=tcp
add action=drop chain=virus comment=Trojan.BingHe disabled=no dst-port=7626
protocol=tcp
add action=drop chain=virus comment=Trojan.NianSeHoYian disabled=no dst-port=
19191 protocol=tcp
add action=drop chain=virus comment=NetBull.Trojan disabled=no dst-port=
23444-23445 protocol=tcp
add action=drop chain=virus comment=WinCrash.Trojan-1 disabled=no dst-port=
2583 protocol=tcp
add action=drop chain=virus comment=WinCrash.Trojan-2 disabled=no dst-port=
3024 protocol=tcp
add action=drop chain=virus comment=WinCrash.Trojan-3 disabled=no dst-port=
4092 protocol=tcp
add action=drop chain=virus comment=WinCrash.Trojan-4 disabled=no dst-port=
5714 protocol=tcp
add action=drop chain=virus comment=Doly1.0/1.35/1.5trojan-1 disabled=no
dst-port=1010-1012 protocol=tcp
add action=drop chain=virus comment=Doly1.0/1.35/1.5trojan-2 disabled=no
dst-port=1015 protocol=tcp
add action=drop chain=virus comment=TransScout.Trojan-1 disabled=no dst-port=
2004-2005 protocol=tcp
add action=drop chain=virus comment=TransScout.Trojan-2 disabled=no dst-port=
9878 protocol=tcp
add action=drop chain=virus comment=Backdoor.YAI..Trojan-1 disabled=no
dst-port=2773 protocol=tcp
add action=drop chain=virus comment=Backdoor.YAI.Trojan-2 disabled=no
dst-port=7215 protocol=tcp
add action=drop chain=virus comment=Backdoor.YAI.Trojan-3 disabled=no
dst-port=54283 protocol=tcp
add action=drop chain=virus comment=BackDoorTrojan-1 disabled=no dst-port=
1003 protocol=tcp
add action=drop chain=virus comment=BackDoorTrojan-2 disabled=no dst-port=
5598 protocol=tcp
add action=drop chain=virus comment=BackDoorTrojan-3 disabled=no dst-port=
5698 protocol=tcp
add action=drop chain=virus comment=SchainwindlerTrojan-2 disabled=no
dst-port=31554 protocol=tcp
add action=drop chain=virus comment=Shaft.DDoS.Trojan-1 disabled=no dst-port=
18753 protocol=tcp
add action=drop chain=virus comment=Shaft.DDoS.Trojan-2 disabled=no dst-port=
20432 protocol=tcp
/ip firewall mangle
add action=mark-connection chain=input comment="" disabled=no hotspot=auth
in-interface=WAN1 new-connection-mark=WAN1_conn passthrough=yes
in-interface=WAN2 new-connection-mark=WAN2_conn passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=WAN1_conn
disabled=no hotspot=auth new-routing-mark=WAN1 passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=WAN2_conn
disabled=no hotspot=auth new-routing-mark=WAN2 passthrough=yes
add action=mark-connection chain=prerouting comment="" disabled=no
dst-address-type=!local hotspot=auth in-interface=Local
new-connection-mark=WAN1_conn passthrough=yes per-connection-classifier=
both-addresses:2/0
new-connection-mark=WAN2_conn passthrough=yes per-connection-classifier=
both-addresses:2/1
add action=mark-routing chain=prerouting comment="" connection-mark=WAN1_conn
disabled=no hotspot=auth in-interface=Local new-routing-mark=WAN1
passthrough=yes
add action=mark-routing chain=prerouting comment="" connection-mark=WAN2_conn
disabled=no hotspot=auth in-interface=Local new-routing-mark=WAN2
passthrough=yes
add action=masquerade chain=srcnat comment="" disabled=no
add action=masquerade chain=srcnat comment="masquerade hotspot network"
disabled=yes src-address=192.168.0.0/24
disabled=yes src-address=192.168.10.0/24
add action=netmap chain=dstnat comment="" disabled=no protocol=icmp
to-addresses=100.100.100.100
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
Can you please post them as text output wrapped in
 tags? Thanks.
i post all as bast i can :slight_smile:
i edit my mt data .
/queue simple
add direction=both disabled=no interface=Local limit-at=1G/1G name="file server" target-addresses=192.168.0.254/32
move [find name="file server"] [find name="asmil dish"]
That said, you should look into PCQ.
