how to cache pages !!
I want to cache all pages in the web-proxy (i’m using x86-v3.22) but it is not caching any data in the disk
[admin@MikroTik] /ip proxy> print
                 enabled: yes
             src-address: 0.0.0.0
                    port: 8080,8051,8052,8053
            parent-proxy: 8.8.8.8
       parent-proxy-port: 0
     cache-administrator: "sniper.daoud@hotmail.com"
          max-cache-size: unlimited
           cache-on-disk: yes
  max-client-connections: 600
  max-server-connections: 600
          max-fresh-time: 3d
   serialize-connections: yes
       always-from-cache: yes
          cache-hit-dscp: 4
             cache-drive: primary-master
and i redirected all packet to port 8080
it is navgiting normally and all pages can be opened but there is nothing in the disk.
it is necessary to configurate Access,Direct,Cache?
You do not have to set anything more than you already have, for it to work, but I would recommend you check this webproxy is only accessible from authorised networks, the wiki manual explains how to add access rules.
One thing, your settings have a parent proxy on 8.8.8.8 on a port of 0. Is that correct or did you edit it before saving here to protect the information of your real parent proxy? If you do not have a parent proxy, then that should not be set.
this ip 8.8.8.8 is for external router D’link
/ip route> add gateway=8.8.8.8
i want cache in mikrotik not in external erver cache :confused:
8.8.8.8 is Google’s primary public DNS server.
Then you need to first setup your network correctly! :slight_smile:
You can’t use 8.8.8.8 as an IP for your Dlink, as fewi states, it belongs to Google for one of their DNS servers. I think you have taken the wrong information from your Dlink router! 8.8.8.8 cannot be the IP of your default gateway. Maybe the Dlink has 8.8.8.8 as it’s DNS setting?
Remove 8.8.8.8 from Mikrotik settings and also check your Dlink is setup correctly.
ok how can configure the mikrotik if i want to connect web-proxy to external router for example i fixed the ip 192.168.1.1 for external router and and the ip for mikrotik is 192.168.1.2/24
the parent-proxy must same the ip for external router ???
is necessary to configure (parent-proxy, access, cache, direct, gateway(/ip route), dns (/ip dns), queue)
sorry for this question but i’m new in this router and i not understand this in the wiki :confused: :confused: :confused:
and thank all for helping me
Do you actually have another proxy server? If not, leave the parent proxy field blank, and try again.
ok thank you :slight_smile:
