hi guys
i got an issue.
i want to make a wireless link in ideal scenario. no objects in the middle and no interference.Like the perfect scenario.
i have been looking for hours how to calculate all the things i need i have nt found an answer that i can fully understand.
let’s say i got two towers of 20 metters height (65 feet)
5 miles apart from each other or 8km
lets use mikrotik board + mini pci express wifi+ ping tails+some antena. (it can be 2,4 or 5,8ghz)
what formula should i use to know how many mW do i need in the card?
what formula should i use to know how long the pigtail might be or how long? cabling loss
what formula should i use to know how many dbi the antena has to be?
-L = C + 20 * log(D) + 20 * log(F)
Distance Loss at F=
in miles in km 900 MHz 2.4GHz 5.8GHz
1.6 mi 2.5 km 99 dB 108 dB 116 dB
3.1 mi 5 km 106 dB 114 dB 122 dB
5 mi 8 km 110 dB 118 dB 126 dB
6.2 mi 10 km 112 dB 120 dB 128 dB
10 mi 16 km 116 dB 124 dB 132 dB
http://www.cisco.com/en/US/tech/tk722/tk809/technologie…
http://www.afar.net/tutorials/how-far/
http://diydrones.com/forum/topics/question-on-frequency…
The free space loss can be calculated according to the formula
where D is the distance, and F is the frequency in MHz. The constant C is 36.6 if D is measured in miles, and 32.5 if D is in kilometers. The following are some examples of free space losses:
Distance Loss at F=
These figures do not take into account deterioration due to weather. Typically, we recommend allowing 15 dB of “fade margin” to accommodate for weather, antenna alignment, and other miscellaneous losses.
thank you in advance.
pd: i know many ppl might try by learning by doing but i like to know in paper before doing purchase.
