Currently, auto-generated ipsec policies have “Level: require” and “Proposal: default”
How to change these defaults? I need to get all of the auto-generated policies have “Level: unique” and “Proposal: custom”.
Dynamic policies are generated from a template policy. You need to edit these settings under the template policy and it will generate dynamic policies using these settings.
I have already tried edit default template (*T), but it did not help…
Any comments, emils?
Your suggestion not work - dynamic policies always created with “Level: require”.
Maybe, its bug in ROS?
Unfortunately, level inheritance from template policy will only be available in version 7. It is too big of a change to backport it to v6.
