how to change forum password? how to register wiki account?
hi
i want to ask
  1. how to change forum password?
  2. how to register wiki account?
http://wiki.mikrotik.com/wiki/Manual:SNMP
add port for SNMP, port UDP 161, 162
You can change your forum password by going to “User Control Panel” (see upper right corner, left to “Logout”), and from there “Profile” (on the left), and “Edit account settings”.
To create a wiki account, you need to contact “support at mikrotik dot com”, and ask them to make one for you with your desired username. You’ll get a temporary password that you can then change upon your first login.
thanks
Wiki registrations are closed. Wiki is read-only
