Mikrotik Expert:
We buy lots of mikrotik RBs . We need change the default script of RB with big batches at the same time .
But netinstall tools only can change the default script one by one.
Can you give some solution ?
thanks
wei zhang
Mikrotik Expert:
thanks
wei zhang
Have you tried Netinstall FLASHFIG button? It would only take 3-4 seconds per unit:
http://wiki.mikrotik.com/wiki/Manual:Flashfig
The FLASHFIG only config the normal configuration. It cant’ change the factory default script of RB .
When we use Flashfig to flash config , the RB revert to factory default script after use the reset button.
We want to change the factory default script by batch。
Hi Normis:
Do RB has other command or method to change the factory default script besides the netinstall ?
